Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > Other Car Related Discussions
Reply
  #1 (permalink)
Old 06-27-2005, 09:22 AM
Brandy  Alexandre
Guest
Posts: n/a
Re: '91 Civic HB Antenna -- HELP!!!
jim beam <nospam@example.net> wrote in rec.autos.makers.honda:
> Brandy Alexandre wrote:
>> Someone broke off my antenna and I decided I could replace it
>> myself. I bought the new one, snipped the old one and taped the
>> cable to the new to pull it down and through. Welp, the tape
>> unstuck and I pull out the old antenna cable. The dumbest thing
>> in the world I did was not look first to see just where the cable
>> comes in. Now I can't get the new antenna cable down. Worse
>> yet, I just lost a coathanger down there.
>> Should I mention at this point that I'm blonde?
>> Anyway, can someone tell me where the antenna cable comes out
>> under the dahs so I can look in the right place and see if I can
>> (1) retrieve the hanger, and (2) bring down the new cable (taped
>> in a few places, this time)?
>> I appreciate your help. :)
> there's a hole in the side panel just behind the hood release
> lever. just poke the cable from the new antenna down the door
> pillar and it should emerge in the area of the hole. it'll be a
> bit fiddly without using a cable pull, but it is do-able. you'll
> need a light & some needle nose pliers. being a contortionist
> helps too.
Thank you SOOOO much. I got it! I retrieved the lost hanger, was able
to find the feed, and voila! I didn't need the pliers, but, yes, being
a contortionist was helpful. ;)
Brandy**Alexandre®
http://www.swydm.com/?refer=BrandyAlx
Well, would you?
Sponsored Links
  #2 (permalink)
jim beam
Guest
Posts: n/a
> Someone broke off my antenna and I decided I could replace it myself.
> I bought the new one, snipped the old one and taped the cable to the
> new to pull it down and through. Welp, the tape unstuck and I pull out
> the old antenna cable. The dumbest thing in the world I did was not
> look first to see just where the cable comes in. Now I can't get the
> new antenna cable down. Worse yet, I just lost a coathanger down
> there.
> Anyway, can someone tell me where the antenna cable comes out under the
> dahs so I can look in the right place and see if I can (1) retrieve the
> hanger, and (2) bring down the new cable (taped in a few places, this
> time)?
there's a hole in the side panel just behind the hood release lever.
just poke the cable from the new antenna down the door pillar and it
should emerge in the area of the hole. it'll be a bit fiddly without
using a cable pull, but it is do-able. you'll need a light & some
needle nose pliers. being a contortionist helps too.
  #3 (permalink)
Brandy  Alexandre
Guest
Posts: n/a
there.
time)?
Brandy**Alexandre®
Well, would you?
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
