Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > Other Car Related Discussions
Reply
  #1 (permalink)
Old 07-22-2005, 06:31 PM
TeGGeR®
Guest
Posts: n/a
Suspension bushing question...
Need advice!
I'm in the middle of changing all the rear bushings on my '91 Integra's
rear suspension right now and a question just occurred to me.
I know the bushing bolts need to be tightened with the suspension
compressed to its natural state, as it will be in everyday use.
Is it OK to just push the arm up with the jack to approximately the right
height, or does the car actually need to be sitting on the ground and
rolled back and forth a bit before the bolts are tightened?
Pushing the arm up with seems to compress the suspension differently from
when the car is sitting on the ground.
TeGGeR®
www.tegger.com/hondafaq/
Sponsored Links
  #2 (permalink)
Old 07-23-2005, 02:32 AM
jim beam
Guest
Posts: n/a
Re: Suspension bushing question...
TeGGeR® wrote:
> Need advice!
i've tried both, and the latter way definitely achieves the best result.
you can access all the necessary bolts from the ground if you don't
mind lying in the driveway.
yes, but you need to do this anyway to get the lower arm bolts in. then
you can do whatever you need before full reassembly.
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
