Other Car Related DiscussionsDiscuss all other cars here.
Welcome to Fit Freak!
Welcome to Fit Freak,
Thought my fuel pump went out - replaced it, but still won't run. Replaced
relay next, and it ran for around 50 miles and quit. Now won't start.
No electricity to fuel pump - blue wire from ignition coil dead. #1 fuse
going to relay is hot. I'm stumped. Any help would be greatly appreciated
- I need a car running by Monday morning!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
"saltydad58" <saltydad1@nospam.cox.net> wrote in
news:0cebcaad51790547f7cc41d0b2d2ebac@localhost.ta lkaboutautos.com:
> Replaced relay next, and it ran for around 50 miles and quit. Now
> won't start. No electricity to fuel pump - blue wire from ignition
> coil dead. #1 fuse going to relay is hot. I'm stumped. Any help would
> be greatly appreciated - I need a car running by Monday morning!
When a fuse gets hot, it sometimes means there's a corroded or loose
connection in your fuse box. Once the fuse gets too hot, it will blow,
since it's easier to blow a hot fuse. Tegger's FAQ also shows a fix for
wobbly fuses. It's the 'last resort' if you're not willing to take a lot
of time. I'm not sure if this has anything to do with your real problem
"saltydad58" <saltydad1@nospam.cox.net> wrote in message
news:3ab5405bef3b5fdf3debe6718d9fab48@localhost.ta lkaboutautos.com...
> Yes, it's carburated. I'm thinking the problem is electrical in nature -
> most likely in the fuel cut-off relay.
The fuel cut-off relay for the carb uses the tach signal from the coil
(blue wire) in order to keep the fuel pump going. No blue wire, no pump.
> The solution is to probably to get a new coil.
Want to get it started by Monday morning. Do what Preludeprob
did, heeding Jim's warning.
Thanks for all the suggestions - especially to Curly Q and B Squareman. I'm
thinking the coil may be the direction to look. No battery juice to the
blue wire, and we are not going anywhere; and the weather has been hot
here. Today's project: replacing coil. I'll let you know the results.
