Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > Other Car Related Discussions
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 07-17-2008, 06:33 AM
pavel22 is an unknown quantity at this point
The corners of the rings
Because synthetic lubricants don't allow much wear on rings that is the reason for using good hydrocarbon oils during breakin, or about 1000 miles to wear the ring edges in nice and smooth.. The corners of the rings have to wear nice and rounded or tapered to hold that tiny crevice of oil between the ring and cylinder walls for minimum friction. In fact it has been known that many NASCAR engines used rings that had been machined with those rounded or tapered corners (wanna start an argument with top engine builders, advocate one) to shorten breakin and improve power. Any nicks or chips in those rings cost power and chips and nicks are what you see on those engines taken to rpm limits under load right away.
__________________
Badge brustvergrößerung billig
Sponsored Links
  #2 (permalink)
Old 07-17-2008, 10:22 AM
Supervillain
doctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to livedoctordoom relies on Rep Points to live
Send a message via AIM to doctordoom
did you mean to post this in a thread that had to do with engine break-in questions?
  #3 (permalink)
Old 07-17-2008, 10:59 AM
feddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to livefeddup relies on Rep Points to live
wrong catagory?
I'm actually interested in the question but believe it's in the wrong category. I used to use Mobil 1 when Mobil 1 was new but now allow the dealership to do the oil changes with Honda oil. I still wonder if a proper break in is possible with synthetic from the beginning. I did the 5K break in that honda recomends if course.
__________________
08 BBP MT absolutely stock!
Getting 38MPG with "moderate" hypermiling. Going for 40!
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hub Diameter for Centering Rings? CSquared Fit Shoes 3 07-11-2008 05:35 PM
shift boot ring & gauge cluster rings *painted* George02 Fit Interior Modifications 15 09-24-2007 09:26 PM
Hubcentruc Rings flickerphil Fit Shoes 2 09-30-2006 04:41 PM
advice replacing worn rings pls... Eric R Other Car Related Discussions 10 08-28-2005 07:30 PM
Easy test for worn rings Jason Other Car Related Discussions 0 08-19-2005 05:34 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
