Tire Pressure Question
On my 07 Civic EX I'm running oem spec 205/55/r16 and the door jam says to fill them to 32psi. My nitto tires say 35psi and i have them filled to 40psi.
What will this do?
better or worsen performance and mpg?
What will this do?
higher psi will net you more mpg, but will worsen comfort and potentially performance.
also, high psi can potentially cause tire bursts from
impact (potholes) as the tire has no room/give to absorb.
depending on tires i use, i am usually between 34-38psi cold.
boots11234
10-27-2008 03:55 PM
