Fit 1/4 Mile Times
#42
Thanks for posting this up and taking the time to see what your car will do in the straight. Nice time!
#43
ya I think if I took off the rear wing and adjusted the alignment so that it was closer to 0 degrees camber I would have a better time. I had a 2.1 60 ft on 1 run but I'm missed second. The start felt really good the tires were spinning and was waiting to hook and by the time it hooked I was ready to shift I was about 7500 rpm which is too much for the transmission to go in smooth.
#46
Grrr
Damn it! Need to see more Fit times. Looking to see more late model Fits. Tracks are closing (or already closed). This Friday, temps will be COLD due to the polar vortex dropping down in the midwest. Should make for some quick runs if you have a track open near you.
Come out and get that best time and post up. I'm aiming for a 15.5-15.6 but I have no more tricks up my sleeve until some parts come in. Only relying on the colder temps.
#47
colder temps dont help as much as we want! Especially since our IAT sensors are heat soaked so bad from the factory.
We Fit owners really need to figure out an external IAT sensor setup. Ive always thought of getting a MAF pinout and using a second MAF, using only the air temp wires, and moving it just in front of the filter (dangling lol)
#48
#49
Its the same MAF sensor used in the GE, so its combined with the MAF, hence why it is 5 wires (or 6? been a minute since I looked)
Its very common for car manufacturers to combine air temp with MAF. One less casting piece of plactic, and probably a couple million saved lol
#50
Need to look for where the temperature sensor is mounted as well. Thanks!
#52
Times: 15.264
Reaction Time - .165
60' - 2.407
1/8 ET - 9.914
1/8 MPH - 73.27
1/4 ET - 15.264
1/4 MPH - 90.80
Car
Year - 2015
Model - LX
Transmission - CVT (Automatic)
Mods:
Performance- Custom PRM Cold Air Intake, Maxbore Throttle Body Custom 2.5" - 2.25" cat back,
Aero - Standard
Wheels/Tires(pressure) - 14" Kosei K1 TS/General Altimax Tires (24lbs)
Weight - 2360lbs (Without me in it), 2565lbs with me in it.
Other-
Conditions:
Temperature- 37F
Humidity- 48%
Time of day- 8:30pm
Extra Info:
I'm running 92 Octane!
I'm not going to argue if it makes a difference or not. I will tell you that my timing advance stays pegged at 15.5 during all my runs, at all temps. It does not do this on 89 or 87 octane.
60' - 2.407
1/8 ET - 9.914
1/8 MPH - 73.27
1/4 ET - 15.264
1/4 MPH - 90.80
Car
Year - 2015
Model - LX
Mods:
Aero - Standard
Other-
Conditions:
Temperature- 37F
Humidity- 48%
Time of day- 8:30pm
Extra Info:
#54
No wheel hop! Even with traction control disabled. I still have a lot of work to do with the 60ft. So far so good though, being though it's a CVT.
#56
You are correct, it is 'race trim' but I drive like this everyday. Just got back from grocery shopping with the Misses. No rear seats, spare or jack. I'm nuts I know! Life is short so have fun. Hehe!
#57
Oh man!!! I'm at 2390 after seats, battery, suspension, wheels/tires and exhaust!!!! The GK is LITE...
Very rough math has you close to 140hp as well...
I'm hoping to hit that with E85, custom IM and tuned length intake...
#58
Gonna hit the track tomorrow, IF they open. They may not because it will be about 24F around 8pm. I'm banking of this if they open since I previously ran the 15.2 at 38F.
Looking to crack a 15.0-15.1. Hoping for a 14.9 but we all know that won't happen. I was only kidding about trying to hit 14's before but our Fits are here now. Gonna try anything I can. The cold air ducting has been completely sealed this time out. Fun times! Come out if you by Cecil County Dragway and get a few runs in.
I have been hoping for a stock Acura Integra Type R or late model Honda Civic Si 1/4 mile time.
#59
#60
Super good time again my friend, just for perspective I did a 15.3 in my old car (96 civic cx, B20Z swap (146 hp non vtec), ITR tranny/clutch/flywheel/lsd, AEM intake, stock pea shooter exhaust, middle of the summer temps). And that was with a 2.2 60ft!
So kudos to you, I hope to break the 15s in my GD with, weapon r race header, open header, weight reduction, CAI, vx wheels running 175/60r13 tires.
Unfortunately the headers are out of stock until Feb at the earliest...so i ordered a tanabe medallion touring for a subtle exhaust note on the daily commute.
