Illuminated power mirror controller
Old Dec 31, 2007 | 04:13 PM
kndlewis's Avatar
I finally got around to adding an LED into the power mirror controller.
I took the control apart awhile ago and noticed a perfect space for a bulb behind the 4-way rocker.
Old Dec 31, 2007 | 05:17 PM
fits_all's Avatar
not that i would need it but sure does looks nice man. Props for the idea and going ahead with it. I would like to change the bulb on the drivers power window switch "Auto" letters
Old Dec 31, 2007 | 05:25 PM
Sweet!
Odd thing is...I thought it was illuminated until I tried to find it while at a light yesterday. After fumlbling for a few seconds I realized that it was not illuminated and just looked like it would be! I didnt know it was a semi transparent plastic and I would have never thought to check! Hmmmmm.....Thanks for the pics!!!
Yeah...MORE THINGS FOR ME TO WASTE TIME THINKING ABOUT!!
Old Dec 31, 2007 | 05:46 PM
solbrothers's Avatar
added REP!
Old Dec 31, 2007 | 05:52 PM
ditto!
added REP!
sounded like a good idea...
gosh...I am such a follower....HAHAAHAAAA
Old Dec 31, 2007 | 07:22 PM
Mugen_Dom's Avatar
There's a space there because the JDM mirror switch comes with a light from the factory (although it lights up amber).
Old Dec 31, 2007 | 07:35 PM
YEAH amber!!!! thats what I wanted to do...I was thinking JDM and didnt even know it!!!
Old Dec 31, 2007 | 07:48 PM
kndlewis's Avatar
You could do amber. I did white first but it was too bright. The blue goes well with our gauges.
Old Dec 31, 2007 | 07:53 PM
kndlewis's Avatar
I was certain that we were being cheated out of a light there. I figured Honda was trying to make cost cuts that no one would notice, at least not until after we bought the car.
Old Dec 31, 2007 | 08:21 PM
ChrisN's Avatar
...exactly my thought too! Honda even deleted the side markers. I want those markers so bad on my Fit.
Great mod by the way! By any chance, can you write a DIY on this, with pictures of course? Thanks!
Old Dec 31, 2007 | 08:30 PM
Originally Posted by Fitiful Blue
.By any chance, can you write a DIY on this, with pictures of course? Thanks!
if you wrote a diy for this, you would be my best friend. and id show you my girlfriends hawt bewbz.
Old Dec 31, 2007 | 08:48 PM
Jay Leno needs comedy writers because of the strike- you could get hired as a scab (seriously)-
Old Dec 31, 2007 | 09:03 PM
Any possible way any of you generous chaps can help me find and relocate my jaw to the upright and folded position!!!
HAAHAHAHAAHAaaaaaaaaaaaaaaaaaaaaHAHHAAAAAAAA
HAAAHAHAAAAAAAAA.....
f that I will write one up then....HAHAHAAHAAAAAA
ouch...damn! hurt my chest again!
I gotta stop doing that...
STOP BEING FUNNY PEOPLE!!!
Last edited by Snap Fit; Dec 31, 2007 at 09:04 PM. Reason: I can't think when im in pain!!!
Old Dec 31, 2007 | 09:16 PM
Please guys, lets keep this on topic.
Old Dec 31, 2007 | 11:05 PM
kndlewis's Avatar
I cannot be bribed!
But here's a DIY anyway;
If you are the slightest bit competent with a soldering iron or know someone who is, you should be able to perform these steps.
If you totally screw up the switch assembly, Bernardi parts sells them for about $45.
As is customary,
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, nor FITFREAK.NET endorse, recommend, encourage nor take any responsibility for the outcome of someone else doing the following. You follow these steps at your own risk!
Push your mirror switch control out of the panel. Open the fuse panel cover and wiggle/push from behind.
Separate the bottom from the switch. Do not operate the switch or the toggle while separated. There are little springs and things that can get lost.
Note the little parts and the molded walls that will limit how much room you have to work with.
The circit board you will be attaching your LED to:
Your LED is polatiry sensitive. Your attachment points:
I attached the + lead of the LED along the jumper wire with a little flux and solder. I then attached the dropping resistor to the - (neg) lead of the LED and slipped on a piece of shrink tubing for insulation. Then attached the other end of the resistor to the - (ground) pin. You want the LED to be positioned directly over the top of the split post and as close to it as you can get. Trim the excess lead wires.
Snap the assembly back together carefully and check toggle operation.
The light will be on anytime the ignition is on. This set up is clean and totally unobtrusive.
I started with a 5 mm white LED, superbrite 13000 mcd intensity. WAY TOO bright!
The light I have in there now is a 5 mm blue 5000 mcd. Much better but still too bright, I think. I would recommend something less than 3000.
I put a little piece of tape, cut in a circle, on the tip of the LCD. This reduced the direct shine into "MIRROR" and looks much better now. I took the pictures above before the little-piece-of-tape trick.
Old Jan 1, 2008 | 12:23 AM
B( * Y * )BIES's Avatar
Happy New Year and thumbs-up on a cool little DIY tip! W3RD!
Old Jan 1, 2008 | 12:27 AM
Thanks man for the awesome DIY!
Old Jan 1, 2008 | 12:56 AM
haha forreal!!
Old Jan 1, 2008 | 12:57 AM
nice SN lolz
Old Jan 1, 2008 | 11:26 AM
huh, cool idea. i might try this later on with a low-watt LED.
thanks for the writeup.
