i need a DIY for skunk2 catback exhaust
Old Mar 3, 2008 | 10:48 PM
Hondasforlife's Avatar
hello my friends well i just baught my exhause now one problem i dont know how to put it on..i heard its simple and i got the rights tools anyone here can point me in some kind of direction would be great and very much appreciated..thank you
Old Mar 3, 2008 | 11:30 PM
yeamans17's Avatar
I would start by unbolting the axle back section from the b pipe, then remove the axle back section from the hangers, then proceed to unbolt the bpipe and remove it from its rubber hangers as well, then install the new exhaust in reverse order
Old Mar 4, 2008 | 12:35 AM
George02's Avatar
yea pretty much what he said... its too easy, if you cant figure it out then I dont kno what to tell you???
Old Mar 4, 2008 | 01:51 AM
I hope this helps... I would haved scanned it in but it was quicker just to sketch it on the comp. Its a relatively simple set up.
good luck
Last edited by Snap Fit; Mar 4, 2008 at 01:52 AM. Reason: forgot a very important word....oooooooooooo
Old Mar 4, 2008 | 03:43 AM
s0x's Avatar
s0x
hey bud i just installed this its totally self explanitory and simple all you need is a socket wrench and a 12mm and 14mm socket the rest is DIRECT REPLACEMENT. the hardest part is getting hangers undone. have a friend there. honestly you dont need a diy just go under the car and it should make sence. and if it doesnt you gotz no business moding your car :P good luck man give it a try you wont hurt anything have fun.
Old Mar 4, 2008 | 08:00 AM
yeamans17's Avatar
I find that it makes getting these off so much easier if you spray some white lithium grease up onto the bracket for the hanger then use a large screw driver to pry the hanger off
Old Mar 4, 2008 | 09:25 AM
wow what great responses yeah..welll i will try it tonight and after reading everyones comments i should be able to do it with out a problem..THANXS guys
Old Mar 4, 2008 | 11:11 AM
s0x's Avatar
s0x
if you have any questions you can aim me at any time on my cell phone my sn is gotparmesan but honestly i think you got what it takes kid
Old Mar 4, 2008 | 03:40 PM
x1alpha04's Avatar
someone wrote a DIY in the skunk2 forums
How To: Skunk2 Mega Power 50mm exhaust for Honda Fit
Old Apr 7, 2008 | 11:46 AM
Thanxs Guys I Know Im A Lil Late But I Got It On Perfect And It Sounds Oh So Sexxi Thank You
Old Apr 9, 2008 | 09:11 PM
Fitftw's Avatar
grats on the installation! now go post some pics
Old Apr 10, 2008 | 09:33 AM
Haha I Would Love To..when I Figure Out A Way To Clean The Exhaust And Make It Shiny..lol
Old Jul 6, 2008 | 10:57 PM
Fit4Trav's Avatar
Didn't want to start a new thread.
So undo 2 bolts that attach exhaust and B-pipe(?)
Pull off the rubber vibration/ hanger mounts.
Put new exhaust on rubber vibration/hanger mounts
Bolt new exhaust to B-Pipe with gasket between the 2.
Would I need a new gasket? Car has only 5K miles.
Old Jul 7, 2008 | 06:19 PM
kancerr's Avatar
havent changed my exhaust much but i dont think you need a new gasket esp if youre just changing your axle back, theyre meant to go onto the oem exhaust and should be a perfect fit...
Old Jul 7, 2008 | 06:31 PM
Fit4Trav's Avatar
^^^Thanks
Actually did the install this morning. Took all but about 30mins.
Pictures soon
Old Jul 29, 2008 | 05:20 PM
yea i had to some mods and for some reason when i installed my skunk exhaust it came with new gaskets....i used my oem ones and a just a couple weeks ago i go outside under my car and the gaskets are starting to brake off...almost looks like its disintegrating..so i need new gaskets anyone know where and what size i need?
Old Aug 7, 2008 | 11:11 PM
this is my 60mm skunk 2 check it out!
YouTube - skunk2 60mm honda fit exhaust
Rampage289
Nov 27, 2009 01:31 AM
sevenaprils
19
Mar 2, 2009 11:10 AM
fit2bking
19
Dec 26, 2007 03:12 PM
its.ryu
29
Dec 11, 2007 11:06 AM
