FIT-Vendor Sponsored Group Buys and Sales Organize group buys to get discounts. Only Forum Sponsors may post group buys in this sub-forum. Forum Sponsors will have "FIT Vendors" in their user title and have gone through a screening process by FIT Freak staff.
KraftWerks Fit Supercharger Kits
Old Jun 20, 2008 | 05:36 PM
Fit MT Base Kit
Included Items:
• Rotrex C15-60 Supercharger at 5 PSI*
• Rotrex Self-Contained Oiling System with Oil Cooler
• KraftWerks Recirculating Bypass Valve
• KraftWerks Automatic Belt Tensioning System
• KraftWerks SuperCard Engine Management Unit
• KraftWerks Aluminum Intake and Discharge Piping
• KraftWerks Silicone Hoses
• KraftWerks Oiled Air Filter
• KraftWerks 5-Rib Belt
• KraftWerks Brackets and Hardware
Order Today!
Fit AT Base Kit Included Items:
• Rotrex C15-16 Supercharger at 5 PSI*
Pre-Order Today! Receive 10% off when you pre-order!
*Boost level is determined at sea level, and can change depending on modifications, weather, altitude, etc.
-CARB Pending-
About KraftWerks:
KraftWerks was started to house all of our Rotrex-powered supercharger kits by Jackson Racing. We believe the Rotrex product will be able to grow with this brand into the future.
KraftWerks is made up of us at Jackson Racing, with Oscar Jackson Sr. at the helm and the rest of our Jackson Racing supercharger engineers. The same quality and technology that you have known of JR, will be with KraftWerks, and will be better than ever. We have improved our supercharger design techniques and have learned quite a bit on the Rotrex supercharger from recent testing.
KraftWerks will establish its own distribution by the time of the release of our new kits. No other companies will be responsible for the distribution of KraftWerks supercharger kits.
We appreciate the support of the Fit community very much! We are very excited about our new venture, and hope the Fit community is ready for some boost!!
The Fuel Electronics:
The new SuperCard utilizes newer software than our previous PowerCard. Also, the SuperCard is not a "basemap" to get you to a dyno or to "get you down the road." Also, the SuperCard really isn't a "piggyback" by traditional standards.
We spend a lot of time testing to get the electronics to work perfect across a whole range of situations; much like a typical OEM manufacturer tests their cars to work across a range of situations. We take pride in our SuperCard electronics and other electronics. We have revolutionized a new way of tuning vehicles.
The reason they are so small? That's because we use cell-phone technology, to make small chips and boards. This makes it simple for our customer to install, and it works seamlessly with the vehicle; at all throttle positions, all altitudes, all temperatures, all conditions.
To produce a CARB-legal product, it has to work. But we take it a step further and not just pass CARB regulations, we make it so it performs on the track, at full throttle, on the street, idling in traffic.
The SuperCard sees injector duty cycle output and manifold pressure. The SuperCard contains proprietary software that is able to determine proper management for all different types of conditions.
General KraftWerks Kit Information:
-The KraftWerks kits and Rotrex supercharger have a 2 year warranty.
-The Base and High-Boost kits are made to be used on completely stock engine components.
-There will be an upgrade path from Base kit to High-Boost kit.
-High-Boost kit information is not available currently.
-Any aftermarket cat-back exhaust can be used with the KraftWerks kits.
-The stock MAP sensor is utilized in both the Base and High-Boost kits. No problems using the stock MAP sensor.
-The KraftWerks kits use a single belt in the system. We have had great belt life, and no issues with our belt drive. We recommend having an extra belt at home, or in the trunk on a long trip. Having a spare belt also makes it easier when you decide to change your belt. You can change it instantly, and then order another spare or two from us while you drive around on your fresh new belt.
-We include an automatic tensioner with our kit (stock car uses a manual tensioner) to help increase constant belt tension and reduce belt slipping. The automatic tensioner also increases belt life.
We have had excellent wear (meaning low wear), and have had no belt related issues. But I would expect to change the belt a little more often than stock, because the supercharged belt must work a bit harder.
-Fuel Electronics are always standard with our kits, and require no additional tuning.
-Automatic Fits will be able to get the Base kit.
-A/C is fully-retained
-Our kits have no check engine lights and are a full bolt-on system. Your factory OBDII system will work as normal with our kit.
-We will confirm international compatibility once our production pieces our available. We will be sending these pieces to Rotrex partners throughout the world to check Right Hand Drive Fit/Jazz. We believe that we should have no problems.Unfortunately, the kit will be available in North America only upon initial release. We will get out international testing complete, and then the kit will be available to all Fit/Jazz owners...
-In order to meet CARB specs, we have used the stock injectors with our SuperCard unit. And these stock injectors have been our big limitation, and we have reached the limit for the little Fit injectors at 121whp. Remember this is the Base CARB pending kit.
We will be releasing a Hondata Reflash package in June as an option for header/cat-delete Fits. This reflash will add many new features for the Fit, including raised rev limit, removed speed governor, adjusted VTEC, etc. This option will also be upgradeable to the High-Boost kit!
We have tested a few different cat-backs, and they all have shown minimal gain. On a S2000, for example, we found a cat-back system that lost over 50 WHP!! The biggest performance gain you can do for your Base SC Fit is ultra-light wheels and high-performance tires.
The Rotrex Supercharger:
-The Rotrex is small; about the size of the turbo it competes against. It has a traction drive, but is sans the turbine of course.
-The Rotrex drive system is a planetary traction drive system. This patented drive allows the Rotrex to spin to extremely high RPMs. There is some calculated slip in the system, but it is very small. This drive has no cut gears, which allows the Rotrex to be ultra quiet.
-The traction drive system has been tested to over 500,000RPM! Compressors wheels will not live at that RPM though. The smallest Rotrex unit spins at 201,000 RPM all day long!
-It uses the same compressor wheels and housings as its turbo opponents, because the drive system can turn the proper RPMs.
-The Rotrex supercharger pumps its own Rotrex SX100 oil, so there is no need to tap the oil pan or add an oil pump. A small Rotrex reservoir is included, along with a small oil cooler for the Rotrex oil.
-The Rotrex SX100 traction oil should be replaced every 50,000 miles or 2 years. If you are doing some heavy track abuse, I recommend changing the oil more often. The bottle included with the kit will cover your first 50,000 miles or so under normal conditions.
-The ratio in the Rotrex supercharger never varies. The C15-60 supercharger used on the Fit kit has a 12.67:1 ratio.
-The supercharger pulley size changes the speed of the Rotrex, just like any other traditional supercharger.
Stock (Red) vs Base Kit on Stock Fit (Blue)
Stock (Red) vs Base Kit with Exhaust Mods (Blue)
Kits for the Manual Fits are in stock, ready to ship!
-Oscar Jackson Jr.
Old Jun 20, 2008 | 05:41 PM
junior40er's Avatar
Nice. Everything is so easy to understand.
Old Jun 20, 2008 | 09:00 PM
mnapuran's Avatar
yea.. except all the pricing breakdowns
Old Jun 20, 2008 | 09:19 PM
Old Jun 21, 2008 | 12:04 AM
espo79's Avatar
im confused.... i seen this new thread and got excited i thought the high boost kit was now avail and priced AAARRRRGGGGG!!!!!!
Old Jun 21, 2008 | 09:24 PM
AtticusFit's Avatar
OJ's kits are awesome, been dealing with them for years and actually had had one when the first 99 civics came out (one of the first) loved it just power all the time loaded down, a/c on, just power all the time.
would mind getting another depending on price for the AT.
Old Jun 23, 2008 | 03:15 AM
xxmostwantedxxx's Avatar
Ok i was wondering if anyone with a supercharged or turboed fit could give me digits according to the new 0-60 time est.
Old Jun 27, 2008 | 09:20 PM
JDM_DOHC_SiR's Avatar
How much longer untill you have the CARB approval..???? big selling point.. for us California users..
Old Jul 13, 2008 | 02:18 PM
CuTeBoi's Avatar
same here, and wondering about the price down for the AT Base package, wish it was possible to get the High pressure one, but I guess it's not possible.
PM please =D
Old Jul 14, 2008 | 03:28 AM
yukfoo77's Avatar
I live in Phoenix AZ. right now, and am wondering if there are any heat concerns with this kit? And does the 10% off apply to the manual kit?
Old Jul 14, 2008 | 11:40 AM
No heat issues. I live in the desert of Socal and have taken 2hour+ trips in 110+ heat with no problems.
Old Jul 14, 2008 | 12:15 PM
CARB Approval is right around the corner!
Old Jul 14, 2008 | 12:18 PM
PM please =D
PMed
Old Jul 14, 2008 | 12:20 PM
No heat issues at all. We test thoroughly in the desert heat. Also, the Rotrex stays very cool.
The 10% off for Manual kits was during the spring Manual Fit Pre-orders.
Old Jul 14, 2008 | 12:28 PM
vinnimac's Avatar
The ad states the injector kit will be needed if there is a header, or test pipe, but I couldn't find it on your site. Where and how much? Also, if I would do the Hondata reflash, it can't be legally driven on U.S. roads?
Old Jul 14, 2008 | 01:40 PM
Tofuman's Avatar
I want this kit so bad... maybe after my wedding i can start saving up for one of these. unless i can put one of these on my wedding registry?
kudos to kraftwerks for making a clean kit that isn't overpriced and for providing lots of information and dynos.
Old Jul 14, 2008 | 02:38 PM
aliencowboy's Avatar
I work at Edwards AFB, it get HOT up here and have had no heat related issues.
Old Jul 14, 2008 | 02:58 PM
GD3_Wagoon's Avatar
hahahha! DO IT!!!
Old Jul 25, 2008 | 08:57 AM
JFR's Avatar
JFR
Oscar,
When will the kit be ready for the European Fit/Jazz?
Can the kit be used on the L13A?
if so let be be the first to try it out.
Old Sep 13, 2008 | 11:45 AM
thisisntjared's Avatar
does the auto kit have a smaller compressor? if so, how much lower in the rpms does it shift the power band?
they are very nice kits!
OJRKraftWerks
1150
Jan 15, 2016 09:40 PM
OJRKraftWerks
19
Jan 8, 2009 07:58 PM
OJRKraftWerks
542
Nov 14, 2008 07:38 PM
OJRKraftWerks
369
May 21, 2008 01:46 PM
OscarJr@JacksonRacing
539
Mar 7, 2008 12:55 PM
