Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Vendor Marketplace Forums > Tire, Wheel, Brake & Suspension Forum sponsored by The Tire Rack
Welcome to the FitFreak.net Tire, Wheel, Brake & Suspension Forum sponsored by tirerack.com. The Tire Rack Team is very excited to sponsor the FitFreak.net Tire, Wheel, Brake & Suspension Forum. We know how important a role tires, wheels, brakes and suspension play in helping us enjoy our cars and view this as a fantastic opportunity to support other driving enthusiasts. As moderators, we hope to guide the discussion by reducing inaccuracies and providing helpful information. Our years of experience in this industry make us uniquely qualified for this role. We will do our best to answer questions and address concerns in the forum in a timely manner. If you are looking for an immediate response, please feel free to call our toll-free number (877-522-8473) or email one of our sales representatives directly. The Tire Rack moderates this forum as a courtesy to visitors to this site. The information and opinions we provide are for general information only. We do not endorse or prescreen any user’s submissions. We cannot be responsible for any loss that may result from reliance by any person upon any information or opinions expressed or exchanged in this forum. Thank you and enjoy the Forum. Be sure to try the Tire Rack Upgrade Garage FitFreak and The Tire Rack Team
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 05-01-2008, 06:00 PM
Sugarphreak's Avatar
Sugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to live
Quote:
Originally Posted by holloway2006 View Post
So, about anything under 43mm rubbing with a 205 tire... I'm running a 17x7 wheel with a 205 and a 40mm offset and I don't rub unless I have several people in my car.
Anytime you have loading, really push the car in a corner or hit a big dip on a highway you will rub, some people can live with it.... some people can't. I would even go with a higher offset than +43 to avoid rubbing personally. In fact, I would say if you want to run 17's with stock suspension you need at LEAST +45.
I ran 17's with a +42 and I wasn't happy. Lots of rubbing with a 205 tire. Swapped out for another 17" rim with +45, no rubs... then dropped the car down on GF210 springs.... the rubbing returned. I swapped out the 205 for a 195 and hasn't rubbed since regardless of how many people or how hard I push it through a corner.
__________________
For a jolt of pure awesome... just click the sugarphreak button!
  #22 (permalink)
Old 05-18-2008, 04:42 PM
wagonsir is an unknown quantity at this point
I hope Jim@tirerack can respond to this, as it involves their products (although i would also welcome responses from anyone else).
I have some Kosai K1-TS wheels from my 93 Honda Civic hatch. The hatch was stolen last month, but fortunately it still had the winter wheels on it. I replaced it with a new Honda Fit last week and my plan was to put the Kosai wheels on the Fit. But I am a little dismayed to find that the Fit has much higher offset on the wheels than the Civic did.
I have the Kosai K1-TS 15"x7" wheels with 38 mm offset. I have seen a number of posts that say 38 mm offset has problems with rubbing on the Fit, but I am wondering if I can get away with it in my specific case (I don't wan't to have to buy new wheels when I have perfectly good ones already).
I will be installing 195/50R15 Bridgestone RE-01R tires.
I will be installing the Honda camber bolts, which will give me 40' (2/3 degree) negative camber.
I will not be dropping the vehicle.
If my calculatons are right, using 195 instead of 205 tires should gain me 5 mm additional clearance. The 2/3 degree negative camber should gain me another 3 mm at the top of the tire. Will this be enough to allow me to use my (15"x7") 38 mm offset wheels without rubbing?
If so, the K1-TS wheels came with plastic inserts to match the 93 Honda Civic hatch. Do the same inserts work with the Fit, or do I need new ones?
  #23 (permalink)
Old 05-18-2008, 07:48 PM
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
You just might get away with it.
You are correct, typically, that you reduce your tire section by 5 mm but it is the tread width that will rub, not the section. 38 mm is 4 mm less than the minimum non-rubbing we know, without lowering, so theoretically you have a mm to spare. That is helped by your fitting 195/50x15 tires. They are only 22.67" diameter and stock 195/55x15's are 23.44". So that should add some clearance.
Measure your read width and if it is less than 6 and 1/8" inches I'd say you have a better than average chance of making it not rubbing. You will of course have a 3.3% error in your speedo and odo (reads higher than actual or original)but thats pretty reasonable.
PS where are you putting the camber bolts on the rear? I don't think you'll need them anyway front or rear.
Good luck.
  #24 (permalink)
Old 05-18-2008, 08:37 PM
Quote:
According to Bridgestone, the tread width of the P195/50R15 RE-01R is 7.2 inches. Thus, I sure hope you meant 7 1/8" instead of 6 1/8". I will try to get to Bridgestone and measure the tread width myself tomorrow.
You are right, of course, The camber bolts only affect the front. I was going to get alignment shims for the rear. The stock rear camber already has negative camber (1.3 to 1.5 degrees?), so I thought I'd just get a 0.5 degree shim. Although, I'm not clear if the shims increase or decrease camber.
  #25 (permalink)
Old 05-19-2008, 08:33 AM
I agree that you should check the tread width.; 7.3" on a tire that is 7.67" section width seems a bit much but it can be that wide. Even so, I am reasonably sure you can install without rubbing thanks to the short tire if it is really 22.67" diameter. I haven't been to Bridge's site but check that the diameter is not 23.5" or so because you may then get rubbibg.
Reply
Tags
16r, 20550, fit, honda
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
