2007 Fit Problem(s)- 67,000 miles
Hey Everyone, I recently bought a 2007 Honda Fit about a week and a half ago. It has roughly 67,000 miles on it. Currently, I have a love hate relationship with the car. Literally the day after buying the car I was experiencing the rough idles at read lights on my way home (bumper to bumper commute on way home, straight shoot to work in the morning). No issues in the morning usually and the car runs great! There was some rough times accelerating/ decelerating the car. RPMs would take a massive drop during deceleration. I guess this has to relate with misfires.
I swapped the spark plugs out two days ago, which gave a noticeable improvement with the car with the acceleration and deceleration issues. However, still experiencing some misfires from time to time. Also, now the RPM drops between 700-500 while at idle without the AC on. With AC on easily between 800-1000 rpm with performance improvements as well. My next step is to swap out all ignition coils. Should this do the trick, or is there something else I should be aware of? I know there is the big three with fits (spark plugs, coils, and valve adjustment). Has anyone else experienced similar problems like this before, and if so, how did you fix them? I just bought this car after my old one gave out on me, dont really have money for a new car. Please help! Have a great weekend-EL |
Yes, swap the ignition coils! At 67k it shouldn't be due for a valve adjustment, but definitely put it on your list of things to do down the road. Keep us updated!
Originally Posted by Elacy1995
(Post 1428882)
Also, now the RPM drops between 700-500 while at idle without the AC on. NORMAL With AC on easily between 800-1000 rpm with performance improvements as well. NORMAL |
Originally Posted by petelite
(Post 1428883)
@doctor J - So do you think the ignition coils could be the culprit, or should I get the throttle body cleaned as well? How safe do you consider your vehicle to be?
(Post 1428885)
I performed "throttle body bore wipe" and idle relearn which did not get rid of the issue completely. I don't think the rough fuel cut poses significant safety issue, driving next to a rival gang member in big powerful car or impaired driver is far more dangerous:) |
Defintely wouldn’t be bad idea to replace the coils , but could it be a fuel thing perhaps? I’m no engine guru, but that’s not many miles for its age so I feel like it could sat around and gunked up the fuel system/injectors you could try and dump some “injector cleaner fuel additive” stuff in the tank - or if you can swing it - maybe have them removed from the car and cleaned?
i had a Volvo that ran weak and rough and I sent my injectors out to be cleaned (cost me $75ish and I couldn’t drive for 2-3days until I got them back from the injection shop) but it ran much better afterwards. good luck gettin things figured out! |
These cars are also sensitive to type of spark plug used. Did you replace with the OEM type iridium plugs?
Is it an automatic or manual? Asking because I'm wondering if the massive drop on deceleration is due to the automatic downshifting. |
Originally Posted by GAFIT
(Post 1428956)
Originally Posted by doctor J
(Post 1428961)
The fuel injected engines use fuel cut (injectors off) during deceleration, the injection resumes when rpm fall close to idle (based on engine load and temperature)
I'm wondering it the transmission is downshifting. It would take a third gear, 5,000 rpm downshiift to slow down our Fit going downhill. |
https://cimg1.ibsrv.net/gimg/www.fit...281d849255.jpg
With throttle completely closed and vehicle is coasting on the flat road from speeds above 45mph the AT will downshift from 5th to 4th at 31 mph (I'm feeling it) and from 4th to 1st at 10 mph The downshift shows up as bumped rpms. Hopefully the fuel resume and 4 to 1 shift are not happening at the same time otherwise the jolt will be excessive! (not to mention TC unlock!) So out of tune engine (for whatever reason) will result in very unpleasant experience, similar to me driving stick shift (in my 1979 Supra) |
2007 Fit problems
Just a thought,did you change all 8 spark plugs?
Ben |
Originally Posted by Brendan976
(Post 1429100)
Ben |
2007 fit problems
Ah that explains it then. I have the cvt with 8 plugs, over here (UK) a lot of independent garages are not aware that the vehicle has 8 spark plugs. Not that my car ever goes to a garage, I have had it for 15 years great little reliable car.
Ben |
