Rattle / grinding noise when starting 08 base M/T
Still a relatively new owner
this car has 254k understand it’s well worn in when I start the car it has a grinding noise that lasts for about a half second after the car starts it almost sounds like when you hold the key too long starting a car it happens every start not temperature or warm up dependent I’m searching for ideas what I think it could be sticking starter solenoid not retracting the gear quickly enough stretched timing chain i hear abs system can make a noise when starting maybe the vtec system? The car has no noticeable chain noise or throttle lag or cel for any timing related codes the Reddit states people have had chains bad on newer fits but don’t see much on the gd fits most people say they last forever. anyone have similar and find a cause? the length of time it grinds it’s time is consistent and is not hot cold dependent. I’ve driven the car around 7k miles with this and two mechanics can’t find the cause |
Pretty sure it’s the starter — some threads on here about it and some preventative measures… mine does it too especially on cold days. Bumping the starter a couple times before starting seems to help.
Yeap, same issue on my 07 Sport. Bought it 3 months ago with 245000 miles.. its a reliable beater.
Was thinking if its the belt, cause it screeches sometimes when driving. |
Mine may be the chain but it has no other symptoms of a loose or stretched chain, I may try to swap starters and see if it resolves but yeah I’ve put almost 7k on it since I’ve had it in 3 months and it’s reliable and drives everywhere
