Occasional Hesitation "Off the Line", Poor MPG
Old May 19, 2025 | 02:29 PM
Joe Clark's Avatar
My 2008 Honda Fit occasionally hesitates when accelerating away from a stop or very slow speed. Also, in the winter when cold the idle sometimes gets very low (it died once in the wintertime when going from R -> D). These issues don't happen often, but often enough to notice. In other news, my Fit also gets pretty poor gas mileage, in my opinion. The original stated MPG was 27/32, and I don't think I've seen anything over 24 (summer, winter, in town, mix) for a year or more. Do you think these symptoms are related and could point to a need for a plugs/wires refresh? I'm sure they are due for a replacement, but I've been hesitant to spend the money without some assertions that they will actually fix this issue. Thoughts?
Old May 20, 2025 | 01:34 AM
2015LXFIT's Avatar
I'd be more leaning towards plugs + an air/fuel issue. Generally ignition issues are straightforwards, misfire. Misfire... Misfire....
Air/fuel ratio is basically the mix of what determines gas mileage. Start with looking at plugs/wire resistance if it does run wires, then check LTFT, IAC, sensors, etc. Could be a multi factor issue. Good luck.
Old May 27, 2025 | 11:14 AM
frog03's Avatar
Classic valves need adjustment symptoms
See the sticky
Momosc
Mar 26, 2025 02:30 AM
Kdawgz
Mar 2, 2015 07:59 AM
SuperFit68
Nov 30, 2008 06:37 PM
ephnit
Nov 30, 2008 05:01 PM
Gordio
Dec 17, 2007 03:36 AM
