Misfire Mystery (NOT Plugs, Coils, Injectors, Lash, Compression) - What's Left??
I'm hoping to get some fresh eyes on a persistent misfire issue I'm having with my 2008 Honda Fit Sport 5spd.
I've done a fair bit of troubleshooting, but no matter what I try, it consistently misfires specifically on Cylinders 2 & 4 (P0302, P0304 & P0300). Symptoms
If the misfire were random, then I'd consider fuel filter, EGR, PCV, etc., but I don't see how those could make misfires always happen on Cylinders 2 & 4. Could this be something related to VTEC? The misfires do happen at the RPMs where VTEC normally kicks in. Though I'm curious how something like a partially clogged VTEC solenoid screen could cause misfires on specific cylinders. Any advice is appreciated! |
Leak-down test to check for valve damage. Electrical - wiring and relays associated with the coils, injectors and ECM, swap ECM itself.
Update / Resolution
After a lot of troubleshooting, I finally got this resolved. The mechanical issue turned out to be just a single bad ignition coil. The main reason it took so long to pin down was that the bad/cheap OBD2 Bluetooth adapter I was running with Torque Pro wasn’t actually clearing the stored codes. The ECU was just stacking new misfire codes on top of old ones. The only times the codes were actually cleared was when I disconnected the battery to change plugs, swap coils, check compression, etc. That's why there was no rhyme or reason to the misfire codes. Bottom line, make sure you have a good OBD2 scanner and, just to be safe, always rescan to confirm codes are truly cleared before continuing diagnostics. |
Hi
I recently sent my car to the mechanic to read the codes for a check engine light (I don't currently own an obd2 scanner) and also have misfires on cylinders 2 & 4. I realised I had a bad ignition coil a few month back when I replaced my spark plugs, so I replaced it. It was the back-side coil of cylinder 2 (I have a i-DSi engine). Because of that my mechanic told me there might be an issue with my coil wiring harness but I find that unlikely. The mechanical issue turned out to be just a single bad ignition coil. |
If you want to diagnose it yourself, you'll need a scanner of some kind. Decent units can be had for $50 or less that will read most basic codes. For $200 or less you can find good units that will also read & reset ABS, SRS, TPMS, etc.. Just be careful with the cheap $10 Bluetooth adapters, that's what I'd been using. I've had several before and never had an issue until this current one.
The standard way to test the coil is to move it to another cylinder. For instance, if you get a misfire code for cylinder 2, trade that coil with the one on cylinder 1. Clear the codes and wait for the check engine light to come on again. When it does, if the misfire code moved to cylinder 1, then you know the coil you moved is bad. If the code stays on cylinder 2 then the coil was probably fine and you should look at spark plugs, fuel filters, injectors, etc. which are far more common than a failing wiring harness. |
| All times are GMT -4. The time now is 12:47 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
