2008 Honda Fit – 208k miles – Intermittent P0171 with hot-restart, choking issue
Old Jan 10, 2026 | 08:25 PM
oldBoiFit's Avatar
Exclamation 2008 Honda Fit – 208k miles – Intermittent P0171 with hot-restart, choking issue
Hey Everyone,
I have a 2008 Honda Fit with 208,000 miles and I’m dealing with an intermittent P0171 (System Too Lean). To better describe the issue, here is the exact scenario:
In the morning, when the engine is cold, the car starts perfectly. Idle is smooth, acceleration is strong, and it drives normally. Even with stop-and-go traffic at red lights, everything feels fine. However, after driving for about 30 minutes, if I turn the engine off and try to restart it 5–10 minutes later, the engine cranks but does not start. If I wait another 5–10 minutes, it will eventually start, but it struggles badly. Acceleration is very weak, the engine feels like it is choking or starving, and it sometimes feels like it might stall.
The P0171 code appears intermittently — I can clear it and it may stay off for quite a while before coming back.
I also removed and cleaned the MAP sensor with spray and reset the ECU using an OBD scanner. After that, the problem seemed fixed for one day — acceleration improved and the check engine light stayed off — but the next day the same symptoms returned and the P0171 check engine light came back.
I’m trying to determine whether this is caused by a vacuum leak (PCV hose, intake manifold gasket, brake booster hose, etc.), a fuel delivery issue, or a sensor problem.
Any advice or similar experiences would be greatly appreciated.
suprman182
Nov 30, 2021 08:57 PM
phenoyz
Nov 11, 2016 01:34 AM
phenoyz
Apr 14, 2015 10:16 AM
hydrogennine
Sep 7, 2011 11:59 PM
Velikimrav
Canada Fit Forums & Clubs
Apr 12, 2007 12:57 PM
