Any GDs upgrade with Hawk HPS pads?
I heard that the GEs have the same brake pad size and all as the GDs. I'd like to get the Hawk HPS pads for my GE.
Can anyone verify that these are the right ones, even though it doesn't list the Fit on the applications? Thanks. Amazon.com: Hawk Performance HB418F.646 Brake Pads - Acura, Honda: Automotive |
Originally Posted by CrystalFiveMT
(Post 482393)
Can anyone verify that these are the right ones, even though it doesn't list the Fit on the applications? Thanks. http://rover.ebay.com/ar/1/711-53200...2&toolid=10001 http://rover.ebay.com/ar/1/711-53200...2&toolid=10001 Amazon.com: Hawk Performance HB418F.646 Brake Pads - Acura, Honda: Automotive |
Thanks.
Now how bout the rear drums? Is there any upgrade available for it? |
yeah switch them over to discs
Don't wanna switch to discs. Is there another option?
(Post 482613)
Thanks.
Now how bout the rear drums? Is there any upgrade available for it? Since my FitJazz has rear discs I didn't investigate that but the best way to find out is to see if the Fit rear pads are common with any other Honda drum. Start with the mid nineties Civics and even eighties CRX. That won't be easy. If your dealer parts manager is an enthusiast he can be great help if he stocks some pads or has an experienced brake tech. However, all that may be unnecessary because the rear drums do so little of the braking effort, better shoes are probably not productive. The switch to rear discs is advantageous because discs are better stopping devices partly because of better pads availability. The rest because of better contact between rotor and pad compared to shoes on drums. A&J racing has a good changeover kit I understand. |
Thanks.
I'll just do the front Hawk pads and see how I like them. As long as there will be much less brake pedal effort to stop and shorter stopping distances I'll be happy. |
(Post 483400)
Thanks.
I'll just do the front Hawk pads and see how I like them. As long as there will be much less brake pedal effort to stop and shorter stopping distances I'll be happy. Don't expect much changes in pedal effort nor shorter stopping unless you change tires. No matter how hard you press the brake pedal the final result is tire to road adhesion. It'll make most change at slowing the distance from 100 to 30 mph repeatedly on any tire unless the tire is so weak that you can lock up the discs or drums. |
No, there should definitely be a difference in pedal feel and effort due to the pad makeup. I had these on my RSX-S and it made a significant difference in those respects.
So what I mean by "stopping distance" is the distance traveled under "X" pedal effort. Not ultimate stopping distance. |
Does Hawk happen to offer the HP+ pads for the front brake calipers? I currently have them on my 1999 Honda Civic DX Hatchback, and absolutely love them.
upgraded to ebc greenstuff. so far - much better than stock.
anyone know if the spoon pads work?
i don't think they do |
I will be upgrading to Endless pads in the front when the time comes.
pshhhhhh baller
Originally Posted by GD3-Fit
(Post 485999)
pshhhhhh baller
They cost a lot, but they bite hard. |
