HELP !!! 16x8 rims, good offset anyone ??
Old Feb 25, 2009 | 01:33 PM
i dnt f!t's Avatar
Question HELP !!! 16x8 rims, good offset anyone ??
hi everyone, i kno this sounds really stupid but. im looking to buy a new set of rims for my fit. and im planning to get 16x8. i was wondering what would be the perfect "OFFSETS" for this size. without the rims sticking out....
any suggestions would help. THANK YOU
Old Feb 26, 2009 | 02:58 PM
AJ PwR Jr.'s Avatar
Former Vendor
I don't think you can find a perfect offset to work on the front. Even if you run 215 tires, it will either rub against the fenders or the against the inside. If you are on stock ride height, you probably get rid of part of the rub :P
I think you have to get wider front fenders then you can run +45 or +35 with 225 tires. If you plan not to run 225 tires then you will loses the entire purpose of an 8" rim.
Old Feb 26, 2009 | 03:25 PM
Tork's Avatar
I was thinking along the same lines, 8" wide forces you into a very wide tire.
Why not a 7" wide rim? That is probably the most common width here on this forum for a 16" wheel (at least pretty sure from reading all/most of the posts here)
You can go on tirerack.com and pick out various tires and click on specs and it will tell you recommended rim widths.
You can also go there and it will tell you which wheels will fit your car (however lowering may not be taken into account)
Old Feb 26, 2009 | 10:15 PM
FITTECH's Avatar
Just get the HFP rims from honda, there awsome wraped in 215/45ZR16 Toyo T1R's. Makes the Fit ride on rails lol. If you want somthing different give them a paint job lol.
Old Feb 26, 2009 | 10:23 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
HFP's are ugly, and heavy.
Theres a few running 16x8's. Problem is with an 8in wide wheel youre limited to space on the inside of the fender wells.
Old Feb 26, 2009 | 10:58 PM
FITTECH's Avatar
HFP wheels
They are a bit heavy but I have not found a pothole to bend them yet, strong like bull. I like reliable performance, if its going to break, bend, make it run bad I dont want anything to do with it. You aint going to win a race if you cant finish it.
Old Feb 26, 2009 | 11:23 PM
Tork's Avatar
^^^^^^ valid point, I bent a SSR Type C last year on a pot hole, I suspect a stock wheel would have come thru it OK
Old Feb 27, 2009 | 11:13 AM
i dnt f!t's Avatar
Ahhh...
Well thanks for the response guys. but after reading the rims and tires thread in here, i decided to get 16x7's the only problem is their only offering the rims with the "ZERO" offset. and i was wondering if 16x7 with a ZERO offset is ok to put on the car, without sticking out too much.
Old Feb 27, 2009 | 01:17 PM
Fit4Trav's Avatar
I have 15x7 +13 and the fronts stick out, the rears not so much
Old Feb 27, 2009 | 03:39 PM
bradthreee's Avatar
0 offset will stick out too much and be prepared to roll your fenders and maybe still rub
Old Feb 27, 2009 | 05:46 PM
FITTECH's Avatar
16x7
stock offset is 55. 0 offset may cause wheel bearings to go and cause added wear on suspention components. Just something to concider, not to mention the rubbing issues. lol good luck on the rim mission.
Old Mar 3, 2009 | 02:59 PM
VBP08GD3's Avatar
the 8 is rediculous dude.. just stick with the 7
Old Mar 3, 2009 | 03:00 PM
VBP08GD3's Avatar
what do u guys think of 15x7 +20 plus adapters?
Old Mar 3, 2009 | 04:29 PM
mahout's Avatar
16x8 wheels with 45 mm offset and 205/45x16 tires. 16x7 likewise will work better and cost less and provide better performance and mpg unless you find some VERY light 16x8's. In short, 16x8 does nothing for you that 16x7's won't do equally well.
p nut
Sep 11, 2014 04:15 PM
TheDilweed
Apr 28, 2012 02:15 PM
ccl088
Aug 1, 2011 09:41 PM
crimsona
Nov 11, 2010 09:56 PM
jurassicJAM
Jul 21, 2010 08:44 AM
