my car dies when its cold??!!
Old Dec 30, 2009 | 07:35 AM
mahout's Avatar
Originally Posted by Fit1st
matt i still have the same issue however i just replaced my spark plug and it helps a little. i took it to the dealership and ask what seems to be the issue but they were charging me $100 just to check it so i didnt do it. i will be taking it to another dealership soon and i will keep u updated.
also if anybody here can help that would be awesome!! thanks
Buy an OBD reader from Advance Auto or equivalent for $35; check your codes yourself and next time just tell them what to fix.
Old Dec 30, 2009 | 12:06 PM
Fit1st's Avatar
the problem is there is no engine light
Old Dec 30, 2009 | 06:20 PM
mahout's Avatar
Several codes won't activate engine light and I believe fast idle speed is one. And that one will require reprogramming by dealer. See 11-257 in service manual. I still think your fast idle is too low.
Still you need to know if all codes are really off before going to dealer..
Old Jan 4, 2010 | 08:50 PM
joemango's Avatar
Does it have a rough idle when it's cold? How many miles on the odometer?
Old Jan 16, 2010 | 10:40 PM
Fit1st's Avatar
i finally found the solution to my car problem. i did a valve adjustment and it did fixed the issue. to all that has the same issue that i got you need this adjustment. now my ryde is running like a champ, ima go fine me a corvette to race now. hahaha. thanks all for your support...
Old Jan 17, 2010 | 06:09 PM
wdb's Avatar
wdb
Valve adjustment eh. Interesting. How many miles do you have on your Fit?
Old Jan 19, 2010 | 03:01 PM
Fit1st's Avatar
109k
asklhfdklhff
ktbishop222
Mar 20, 2018 03:03 PM
Globalksp
Jan 3, 2018 08:52 PM
Santiad
Dec 30, 2016 12:31 AM
phenoyz
Feb 26, 2016 02:42 AM
mmdir2002@yahoo.co.uk
Aug 4, 2005 06:30 AM
