^o^ D.I.Y Vertically @ rear wiper :: FIT & JAZZ :: GD
Old Apr 12, 2009 | 11:33 AM
dg748's Avatar
From: :: East DEVIANTS :: SingaporE :: espaceservicepl.com
now you see the bolt,
remove it with 10mm shock
then just remove your wiper n
you should see like this
now we remove the parts that are
attached the black plastic cover
then remove this 2 pins
then after you pull of the black cover
you should see your wiper motor,
remove the three bolt n
the wire cable holding the wiper
motor on your car
now we already remove the motor
there's 4 bolt holding this cover
now this is what you should see,
there should be a plastic pin on the red arrow,
mine don't have because mine is
already being break off...
See the white gear, got 2 holes,
1 is which the arm rest in,
the other got a plastic knob,
break it off & take it out
then put e metal arm
below where u break e plastic knob ...
then remove the metal bar
and move the small metal
which i pointed with arrow
from left to right
you should get this result
& now we put back the metal bar
after that install back everything
you nozzle spray
that is n hose inside just pull out e hose then u can c n nut
( e nut is inside hose ) but u must add n rubber spacer
bcos u need e high so e sprinkler can work well ^_^
:: hv fun ::
Old Apr 12, 2009 | 11:50 AM
Ciggy's Avatar
What does this accomplish?
Old Apr 12, 2009 | 11:55 AM
grtpumpkin's Avatar
Your rear wiper will nest/start from the vertical position rather than horizontal. Its JDM Yo! LOL
Old Apr 13, 2009 | 12:49 PM
that would suck in snow belt states as that blade will aways get
into the way when you want to remove the snow/ice.
but in warmer climates could be pretty cool.
Old Apr 13, 2009 | 02:57 PM
Fit4Trav's Avatar
^^Yeah where I live its helpful cause dust/dirt doesn't accumulate anymore.
Old Apr 13, 2009 | 03:28 PM
i can see that in LA!
Old Apr 13, 2009 | 04:53 PM
Masterdebater's Avatar
true true about the dirt collecting bs...when i find some spare time ill do it prolly
Old Apr 13, 2009 | 06:27 PM
Interstate526's Avatar
i like it. i probably won't do it, but it's still cool.
Old Apr 14, 2009 | 12:00 AM
CuStoMmAdE's Avatar
Thats not bad good work!
Personally I like the Rear wiper delete sense it doesn't rain much or snow in cali!
Old Apr 14, 2009 | 09:42 PM
junior40er's Avatar
I did the vertical wiper delete and I LOVED it cause it help from dirt accumulating on it. I just did the delete though cause I have a spoon spoiler and it hits.
Old Apr 14, 2009 | 10:04 PM
Super Mario's Avatar
I wanna see the pattern on the back window after it's used.
Old Jun 7, 2009 | 01:18 PM
setter11's Avatar
Video: (In Action)
Imageshack - dscn2643.mp4
Pros:
No dust collection
Cons:
When you spray the nozzle, water shoots down to far and gets
a lot of the car wet, since the wiper is out of the original position,
it does not collect the water as it used to.
Old Jun 7, 2009 | 01:38 PM
doctordoom's Avatar
Supervillain
i won't be doing this, but it's still a nice diy write-up
Old Jun 18, 2009 | 01:46 PM
OutkastGS3's Avatar
so much work for this.. but good write up! very clear
Old Jun 19, 2009 | 07:52 AM
dg748's Avatar
Originally Posted by setter11
Video: (In Action)
Pros:
No dust collection
Cons:
it can spray on ur wiper
Old Jun 19, 2009 | 08:23 AM
Arisenfury's Avatar
It's actually not that much work, it took me about an hour. I've been using it for about a year and a half now with no problems.
@kenchan: It actually works pretty good in the snow, the blades don't collect as much snow/ice to smear. I also just pick my wiper blades up during storms too so it doesn't get in the way when it comes time to scraping.
Old Jun 19, 2009 | 10:17 AM
amelsportfit's Avatar
motor on your car
from left to right
you nozzle spray
:: hv fun ::
nice DIY.. i just finished mine just right now and it was easy.. thanks
Old Jun 20, 2009 | 04:17 AM
dbcmaster's Avatar
I changed the wiper to vertical a while back using another DIY guide. I must say that it does help for me in the winter. Makes the snow just fall away.
It also gives you a unique look and usually a question or two from other Fit Freaks.
Old Jun 20, 2009 | 06:19 AM
dg748's Avatar
i c u all r ve fun
Old Jun 20, 2009 | 06:23 AM
dg748's Avatar
u r welcome br0 ^0^
Wing On
May 25, 2025 02:59 PM
dg748
Jun 20, 2009 06:28 AM
dg748
Jun 16, 2009 09:25 AM
dg748
Mar 16, 2009 09:21 AM
junior40er
43
Jul 4, 2008 03:22 AM
