Rear shoulder belt won't stay put!
This is just a minor annoyance, but I wonder if anyone has found a good solution. The rear shoulder belt, which I have never used, continually drops down from the ceiling mount where it lives while not in use, and dangles there in my rear view. It's just a little distracting. No matter how tightly I jam the thing in there, it won't stay for more than a day or two. Any tips for making it stay?
/learn 2 corner
Really, if you (or at least for me) take a turn too sharp/fast the belt will pop out of its slot. One solution I seen somewhere on this forum is where a member removed the plastic slot and I believe they bored out the hole that the belt clips into. I'll see if I can find the thread for you... ...here you go. https://www.fitfreak.net/forums/fit-...g-out-fix.html |
^^^ aha! :D
Originally Posted by Hootie
(Post 695538)
This. I did this because mine was doing the same as yours. Nothing to do with cornering, everything to do with the metal clip being loose. I popped it out of the ceiling and there was no tension on it. |
Awesome. Assuming it's not 112 again this evening, it'll be done by dinner.
Originally Posted by gd3vbp
(Post 695547)
Mine fell out once. I discovered you need to insert the metal latch (as if you were buckling the seatbelt) until it "clicks" (latches in place).
Originally Posted by somdamon
(Post 696493)
Just like somdamon said if you insert the metal latch it will normally stay put. Since 2007 mine has only slipped out twice. Cat: x |
| All times are GMT -4. The time now is 07:13 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
