oem tires & arrow markings
Old Oct 25, 2009 | 07:11 PM
mozarwasagenius's Avatar
The oem tires have been rotated once by the dealer (with an unknown pattern) and once by me (front to back).
I noticed that the directional arrows on the tires point in different directions for the driver and the passenger sides of the vehicle... (For reference, I'm showing the arrow direction when the arrow is on the top of the tire)
Rear Driver Side <- <- Front Driver Side
Rear Pass Side -> -> Front Pass Side
Shouldn't they all point in the same direction? I can't figure out how to rotate them to make this so. Can someone check theirs and let me know.
Old Oct 25, 2009 | 09:32 PM
Type 100's Avatar
They should all be pointing forward.
You'll have to dismount the driver's-side rubber from the wheels, turn them 180 degrees, then remount them on the wheels.
Old Oct 25, 2009 | 10:50 PM
Is that how they rotate tires at the dealership??? I never paid attention before I took it to the dealership so I'm not sure if it was originally that way.
bizarre
Old Oct 26, 2009 | 01:57 AM
Type 100's Avatar
If you have directional tires, the rotation pattern is simply front-to-back. You simply switch the left-front and left-rear tires with each other, and the same with the tires on the right side. This is because you have to make sure all the tire treads are pointing the right way, i.e. forward.
Ignore the spare if you have a full-size one, it's not part of the rotation. Chances are it's not going to be directional too.
Old Oct 26, 2009 | 06:58 AM
Selden's Avatar
If these are the OEM tires that came with the car, then 2 were mounted backwards at the factory, and you have survived this far without anything happening. Don't worry about it. Remounting could cause more problems than it "fixes," as the tires have already broken in.
If they were brand new replacement tires, I would take them back for the installer to correct the error.
Old Oct 26, 2009 | 09:56 AM
yeah, these are oem tires. I have 13K on them so far with this setup
Old Oct 26, 2009 | 10:03 AM
the arrows need to point forward.
as noted above already, directional tires are to be rotated front to back.
Old Oct 26, 2009 | 11:20 AM
gd3vbp's Avatar
I wasn't aware the OE tires were directional... They're an asymetrical tire, but I don't believe they're directional. I'm at work or else I'd go look.
Old Oct 26, 2009 | 11:33 AM
yah, i dont remember it being directional either, to tell you the truth...
Old Oct 26, 2009 | 04:59 PM
Mr_Kunio's Avatar
Directionals or asymmetric tires should say Outside or Inside on them shouldnt they? Mount on the outside with the arrow forward
Old Oct 26, 2009 | 05:35 PM
gd3vbp's Avatar
Yes, they will say outside, however asymmetric does not mean directional.
SilverEX15
16
Feb 17, 2016 05:01 PM
danlisahall@comcast.net
May 28, 2011 08:09 PM
Jodele
Mar 6, 2010 06:36 PM
mozarwasagenius
Oct 25, 2009 07:15 PM
Super Mario
SoCal Classifieds
Jul 1, 2009 08:07 PM
