Just "wasted" $130.
Old Jun 3, 2010 | 09:01 PM
Daemione's Avatar
If these look as good on my car as they do on my lap . . .
Old Jun 3, 2010 | 09:07 PM
Ciggy's Avatar
I need to order these where can you find a white LED replacement for the reverse light and turn signal?
Old Jun 3, 2010 | 11:35 PM
Daemione's Avatar
LED turn signals are easy to find, just about any LED website should carry them. Reverse lights aren't as easy - I'm looking into it now, actually.
Old Jun 4, 2010 | 11:41 PM
Daemione's Avatar
Install wasn't as easy as I hoped, but really not too bad. Anyone with some patience, basic tools, and an IQ over 100 shouldn't have any problem. I ended up needing to extend the wiring for the reverse lights on the driver's side - without pulling upper interior body panels, there was no way there was enough slack. I cannibalized the (now) unused rear taillight harness for the extra 3 inches needed. But like others have found, it does work okay on the passenger side once you undo a couple a few clips.
Getting the reverse lights to fit in the JDM socket is a head-scratcher at first, but a couple minutes of playing with them & you'll figure out the one little block of plastic on the taillights that you can remove to make them lock in like stock.
What I was surprised at, was the incredible amount of sand & dirt I found caked in & on my rear bumper support. I wish I'd emptied my shop-vac before going to work so I could weigh what I found. No joke, there was enough there to grow a medium sized ficus. So if you guys have any excuse to pull your rear bumper, I highly recommend it for the mad weight savings once you get rid of the dirt back there.
Old Jun 5, 2010 | 12:06 AM
Fat Ping Cat's Avatar
Originally Posted by DreaMv
i didnt cut any wires.. i just put the turning signals on the bottom and reverse on top lol
depends how your car is wired... mine had no slack whatsoever
Phyrric
Nov 4, 2013 09:26 AM
bdotarena
Aug 9, 2010 11:15 PM
kayne8570
Jul 13, 2010 07:36 AM
cbs1013
Apr 9, 2009 04:41 PM
ghettoboy247
23
Dec 22, 2008 02:58 PM
