Getting through the GD3's firewall?
I've looked for answers but haven't found them searching the forums. What's the easiest and most tasteful way to get a power wire through the GD3's firewall? I'd like to avoid voiding any warranties and HOPED to avoid just drilling a new hole. I've seen a few pictures where extensive cutting near to critical stuff was involved. I'm trying to minimize damage. Any help would be appreciated. I'm hoping to run a 4-8 gauge wire through to the battery.
theres a plug on the firewall where the main harness comes through. remove that grommit and run it through there. (passenger side)
side?
Which side do I attack it from, the engine compartment or under the dash? Does it push through or is cutting required? Thanks for the response. I just prefer a little knowledge before I dive in!
I found it was easier from the inside of the car. U dont have to cut anything.
Thanks
Thanks for the info. I'm planning on a subwoofer in the passenger side rear corner so I guess I'll run the power wire along the passenger side door sills. Thanks again for the help. I'll get in there tomorrow and look for the grommet. I hate being on my back so at least help on where to start will save some pain (literally).
I drilled a hole in the knockout where the clutch would be (mine is an auto). Snap in grommet and all is well!!
Comes out right behind the battery, I ran a 4ga to my amp from there. GLW the install. Mike |
stick
mine's a manual, of which I'm quite fond, so that's not an option. Thanks for the input. Any other options would be appreciated!
blower removal?
(Post 936213)
Sometimes all you can do is to get something done is to make a decision as to where you can drill a whole and wish for the best.... You know, like Haliburton did for British Petroleum.
(Post 936803)
If things are cramped down in the footwells, as they usually are, use an unfolded coathanger or some fishtape and push that sucker through the grommet (gently) then find the hanger in the engine bay, tape the wire to the hanger and pull it back through. |
Originally Posted by feddup
(Post 936777)
Did you remove the blower? It seems to block access to everything. I see massive bundles of wires running behind it.
I ran a amp on my beater fit, not the SC'd one. |
There's also one on the driver side that's easy to get to from inside the car. It's not visible from the engine bay since the strut tower hide it.
thanks
Originally Posted by Fitting
(Post 936857)
(Post 936857)
(Post 936268)
| All times are GMT -4. The time now is 09:29 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
