RPM drop
Old Apr 17, 2011 | 05:27 PM
hondafit_03's Avatar
RPM drop
Hi All,
I own a Honda Fit 2003, it has done 160,000 kms.
The problem is whenever i shift from N to D , there's a RPM drop and weird vibration in my car ( rpms drops from 800 to 600 or less). I've changed my CVTF lyk before 20,000 kms. The car also vibrates when the brake pedal is pressed on D mode.
Waiting for ya helpful replies.
Thnx
Old Apr 17, 2011 | 06:01 PM
waitin for a quick reply...
Old Apr 17, 2011 | 07:34 PM
Occam's Avatar
Has it always done this?
I'm not sure if the CVT uses a fluid torque-converter like a traditional automatic, but there's always a bit more resistance in D than N. There's enough slippage to let the engine turn without stalling, but still a load placed on it. It's like sitting at a stop with the clutch let out juuuuust a little bit.
If it's something that's changed over time, it may be a concern. Perhaps have a mechanic give it a lookover?
Old Apr 18, 2011 | 04:08 AM
It started lyk 2 weeks ago. The brake pads have about 70% life.
The vibration is ( For instance, when is start the car after 2 or 3 hours and leave it to warm for 4-5 mins, shifting to D from P makes it vibrate and i can see a RPM drop) I've to press hard on the gas pedal. Similarly, on singnal when i push the brake pedal while the car is engaged in D , I can feel the vibration .
Old Apr 18, 2011 | 03:33 PM
anyone ??
Old Apr 18, 2011 | 03:42 PM
The vibration is more when the engine is a bit cold, lyk it gets normal after 10 mins drive...
Old Apr 19, 2011 | 06:36 PM
mahout's Avatar
Originally Posted by hondafit_03
Hi All,
Thnx
Blame it on the load on the engine from the transmission. perfectly normal. If it worries you set the idle rpm when engine is in drive but stopped.
appleica
Oct 12, 2021 05:28 PM
over40pirate
Apr 16, 2013 02:48 PM
Andre Lee
Oct 22, 2012 04:00 PM
xorbe
Jun 4, 2008 05:23 PM
bozerwong
Oct 16, 2007 10:31 PM
