Recirculating vent weaker than outside air
Old Apr 24, 2011 | 07:49 PM
Solscud007's Avatar
So the other day I had to use A/C for the first time this year. I noticed my vents were not blowing that hard. it was cranked to 4 vent face and feet. even on face alone, it doenst feel like a torrent of air.
When i switch to use outside air, then the air is blasting. My windows are closed by the way.
I remember that my Fit was the opposite of this last time I used my AC.
I flipped the switch back and forth and messed with the temperature but still the same problem. Recycled air is just weak now.
any ideas to what the problem could be?
Old Apr 24, 2011 | 08:27 PM
fitisno's Avatar
no problem. all vehicle are that way. it will always be stronger when set on fresh air cause it has the force of the wind being pushed by the vehicle. it will be colder with the inside air selected, but not stronger
Old Apr 24, 2011 | 08:58 PM
Shortcamo02's Avatar
I just bought a 08 fit last Tuesday and I noticed the recirculating vent was much weaker than the outside air. I assumed it was broken.
Old Apr 24, 2011 | 09:04 PM
fitisno's Avatar
no sir. all vehicles are that way. recirc doesnt have the force of incoming air. recirc is good if it smells outside or you want your vehicle to be completely opposite of the outside temp
Old Apr 24, 2011 | 10:18 PM
Brain Champagne's Avatar
I'm pretty sure it was the opposite on my prior car- recirc fan ran stronger than fresh air.
Old Apr 26, 2011 | 12:03 PM
Solscud007's Avatar
Yeah. Recirc should be stronger. The key factor is that my windows are CLOSED. Granted if the windows are open then the pressure difference is decreased and the air has a place to go. But my recirc is on 4 it feels like a 2 on open air.
Old Apr 26, 2011 | 12:16 PM
sooznd's Avatar
the A/C will not need to work as hard if it is recirculating air that is already cool. It should become cooler quicker. If car has to cool hot air from outside , a/c will work harder and be less efficient.
Old Apr 26, 2011 | 12:17 PM
Solscud007's Avatar
Thanks. But im not talking about A/C. Im just talking about the fan speed.
Old Apr 26, 2011 | 12:19 PM
MannyaK's Avatar
Im in Tucson, Az so we all know that heat is a big thing here, i hardly ever use the AC unless the fiance is in the car. when i do turn it on i always keep it at 2 and i do not put it on recirculation, consider checking the air filter located behind the glove compartment
Old Jul 25, 2011 | 08:46 AM
nickroz's Avatar
Take out the cabin air filter in the glove box and let us know if it speeds up back to normal. I came across the same problem last week, so I changed the dirty filter, but it still blows weak unless I remove the filter- plastic tray and all.
Old Aug 9, 2011 | 07:30 PM
jnsluft's Avatar
Check behind the glove box and make sure there is no obstruction. I had a situation recently where the recirc setting gave me almost no air output. The fan, even on "4", the fan would blow, but there wasn't any output. I pulled out the glove box, and I found a piece of paper covering the air inlet. Took out the paper, and the problem was solved. Also, this would be a great time to inspect your cabin filter.
Shawn
Old Aug 28, 2011 | 09:04 PM
jbdoughty01's Avatar
Concur with jnsluft - had numerous instances where a fast food napkin had found its way out of the glove box and covering the air inlet - definitely check that!
Old Jul 15, 2013 | 04:36 PM
pearl's Avatar
Thought my car was broken. This fixed it. Thanks!
FitAK
Jan 24, 2018 07:47 AM
75r90rider
Sep 26, 2014 06:22 PM
MedSupplyFit
Nov 22, 2010 04:54 PM
Sherpa
Sep 2, 2010 03:48 PM
cabingirl
Dec 13, 2009 04:00 PM
