for those that dont already know- Hondata
Old Mar 12, 2013 | 02:50 PM
  #221
TPColgett's Avatar
Originally Posted by thasniperwolf
TPC how's the hondata doing seeing that you've been using it for a while now. Any pros or cons about it? I'm very curious and can't wait to get mine.
Plenty of Pros!
I JUST used it Sunday during my AutoX event to record some detailed datalogs as I was worried about getting things buttoned up and smoothed out before my next big event in San Diego.
I also met up with a new FlashPro user on Sunday who was enjoying his We both talked about it for a bit, he has an auto and me a manual, and we both feel that as long as you keep your foot out of it, there is no real hit to MPG.
Also, remember, that unless you plan to dive in and learn how to do EFI tuning yourself, you really should have your car either Dyno or "E-Tuned."
The choice between the two is really depending on your current power mods, race headers and cat deletes or any type of FI I feel should be put on a Dyno.
Its common knowledge that I have worked with DSM on here for my E tune's and I recommend his services to anyone else looking for the same!
Old Mar 12, 2013 | 03:17 PM
  #222
thasniperwolf's Avatar
Sweet. Can't wait to see the differences it can do for my car so far I have headers catback exhaust and SRI
Old Mar 15, 2013 | 09:20 PM
  #223
lakia5524's Avatar
Flash pro
I definitely can tell a difference between the stock tune and tuned cals got it tuned with flashprotuning.com they don't really do race cals so much its more for reliability everything's good with the tune just been trying get better throttle response smoother pull with the tplate all I have is header back exhaust rpf1s an air intake of course the more I do to the car the more I want like they say its the cheap mans racer cant wait to get a turbo kit eventually im sure with that it will feel a 50 percent increase..
Any one on here have there throttle response to were they got a nice follow though pull I think more of anything I want better lower rpm response not so much drag feeling for low end I could probably play with the vtec window rpm for that mines set for 2300 to 4500 just real cautious not wanting to off balance or wear the car down for what acceptable..
Old Mar 19, 2013 | 10:23 AM
  #224
Hey Tyler just checked out the dyno vid of your car. Sounds very good man congrats!
Old Mar 19, 2013 | 10:52 AM
  #225
DiamondStarMonsters's Avatar
I'm hoping the new tune puts it down better all around, and that the new launch control setting can keep it from blowing the tires off.. even with the 140 wear 225s hes got up front!
Old Mar 19, 2013 | 12:00 PM
  #226
TPColgett's Avatar
Thanks! Soon as it rips up over about 5500 it started to raise some eyebrows from the peanut gallery there at the dyno day They told me the mustache was good for at least like 5whp
I could ALMOST feather the clutch enough on the current revision to only severely chirp my SUPER sticky 195 Toyo's but the 225 RS3's just make fun times if I side step
I will re flash the newest tune on my lunch and maybe actually take a full hour to log some AFR's and such!
Old Mar 19, 2013 | 12:04 PM
  #227
What mods are you running again TPC?
Old Mar 19, 2013 | 12:36 PM
  #228
TPColgett's Avatar
Taken from page 3 of this thread
Originally Posted by TPColgett
The current relevant modifications for power are as follows:
AEM CAI Intake
DC sport 4-1 ceramic header
Skunk2 60mm cat back exhaust
Denso IK-22 plugs and 91 octane pump gas
I am also running AMSOIL Signature Series 100% Synthetic 0W-20, but I do not think that will factor as much.
Here is hoping we see something fun/interesting with just the basic I/H/E GD bolt ons...
Old Mar 19, 2013 | 01:16 PM
  #229
lakia5524's Avatar
Flash pro
What kind of dyno numbers are you getting from the flashpro Tpcolgett?
Im interested because I got damn near the same mods all but the plugs and different brands, sound like your getting nice results..
Old Mar 19, 2013 | 01:17 PM
  #230
TPColgett's Avatar
You will have a PM in little bit
Old Mar 19, 2013 | 01:48 PM
  #231
Just be mindful, the tune I sent last night is considerably more aggressive. There is more I want to do on one of the fuel tables yet. I just want to see where how far we can comfortably go this time for your event.
If you feel timing being pulled consistently in one spot for example, send me the log with some notes ASAP and re-load the last tune (1.1f) while the car is still hot to see if it goes away or if it was a function of environment/course.
Compare the spark and fuel tables, you'll immediately see the difference!
Old Mar 19, 2013 | 02:19 PM
  #232
TPColgett's Avatar
Aye aye!
I figured this one as a fact/limit finding session I'll keep my ears open and eyes on the gauges!
Old Mar 19, 2013 | 02:50 PM
  #233
dewthedew's Avatar
how does the launch control work?
Old Mar 19, 2013 | 02:54 PM
  #234
clutch switch activated rev limiter
Old Mar 19, 2013 | 02:57 PM
  #235
TPColgett's Avatar
It is by far the funnest feature
Old Mar 19, 2013 | 03:09 PM
  #236
dewthedew's Avatar
AH, that must be why it wasnt working for me the other day
What RPM are you guys setting the launch limiter too? and youre setting the recovery to the same RPM correct?
Old Mar 19, 2013 | 03:32 PM
  #237
Send me a PM
Old Mar 19, 2013 | 03:40 PM
  #238
dewthedew's Avatar
i think i did :P ill send you another
Old Mar 19, 2013 | 03:58 PM
  #239
replied!
/tenchar
Old Mar 19, 2013 | 04:07 PM
  #240
dewthedew's Avatar
the drive home from work is going to be fun
