for those that dont already know- Hondata
#262
ill check one out, i have been wanting to see the fits voltage while driving, i think mine is to low and fluctuates from 14 as low as 12.2 as far as i no this is wrong replaced battery but i think alt is next have had stalling but when in neutral or park it go back up to 14 so every time i have a place test it they say its ok any iv check my belt tension id send you a log but not sure how to on this page cant drag and drop
#263
log
Do you have any wot logs i could check out? i want to see how much your throttle plate opens mine only open 88 percent at wot
#265
Yea it would be under throttle plate seen your tpeddle was 102 dont thing mine that high tplate on mines only 88 idk if that normal i tried changing tplate cal but did nothing
#267
There are plenty of displays you can get online if you search for them or look at the hondata forum.
Also scale down your high/low on your datalog for tps. It will help you see the line smooth out so that you can see where you are using partial throttle/cruising.
I set up map and tps on the same datalog screen to help show how the engine is breathing.
#268
Displays | FlashPro Tuning
click display in the top left , then click load it will bring up options to pick.
Once you choose a display you can also edit them by right clicking on the graph and choose sensors .
Making graph Click options click graph templates.
next click add make a name then below edit sensor you want
when your done click add again then exit, then see if its there in graph, there's an arrow you click to open for choices
#269
I'll have to play around with this more. I fucking hate having to do this on my Mac through Virtual Machines. It really is a pain in the ass. I need to buy a cheap laptop for 2015 to use for tuning and testing the Fit.
#271
[QUOTE=Rollerboots666;1281947]I'll have to play around with this more. I fucking hate having to do this on my Mac through Virtual Machines. It really is a pain in the ass. I need to buy a cheap laptop for 2015 to use for tuning and testing the Fit.[/QUOT
no biggy if this make it easier heres my email to send a Wide open throttle log i can check out droyer80@yahoo.com
Yeah I am trying to figure out if my throttlebodys got a issue or if I just need to mess with my tplate more
#272
What about you kylerwho dose your throttle plate open too 100% at wot
do you got a gd3
#273
102% is the highest number I have seen from my datalogs but on my dials it always said 87% was the highest.
Im told that the stock throttle body doesn't see any performance gain from opening the extra 13% but I have not taken the throttle body off to see if it was fully opened when it rear 87% or if it still had some more to open.
Honestly I have not messed with the settings to try and get it to open 100%. Has anyone done this with any benefit?
lakia5524 try datalogging a 4th gear pull from 20mph-70mph. You will see hopefully 14-14.7 on the MAP and that is where you might see 102% on the throttle body %.
#274
yeah my throttle peddle goes to 102 but the throttle plate only 89
I think that's just the way they made the gd3
I wish skunk2 would have made a bigger throttle body for our fits
