15" steel wheels for winter snow tires on 2007 Honda Fit Sport
Hi all,
I am a very infrequent poster, but read here every once in a while, so please tell me if I can change anything about my posting to make it easier to answer.
I foolishly bought snow tires for my 2007 Honda Fit Sport 2 years ago. I say foolishly because I bought 15" tires thinking I'd get 15" steel rims to go with them later. Unfortunately, as many of you probably know, there are no stock 15" steel rims for this car. I should have bought 14" tires and 14" rims, but here I am with 15" snow tires, and I'd like to put 15" steel rims with them if I can. I've been doing some research.
It seems to me that what I'm looking for are 15"x6" wheels with a 4x100mm lug pattern designed for a 56.1 hub bore. The offset of my stock alloys is 55mm, which is not so easy to find. Am I right so far?
If so, my question is this: If I find wheels that satisfy all of the above conditions EXCEPT for the offset, are they usable? Is there a range by which the offset can safely vary? And if so, what is it? I may have found some 50mm offset wheels that match all the other specifications.
If anyone else has had luck using 15" steel rims of any kind on the 1st generation Fit Sport, I'd love to hear what they come off of and where you got them.
Many thanks!
Many thanks!
The rims I've found are a 50mm offset, compared to the stock alloys which are 55mm.
Typically the center of the tire is in line with the middle of the roller bearing cage, so that the bearing doesn't see any bending, just an up/down load.
Find someone selling 09-12 Base Fit steel wheels. There's some in the classifieds here or you may be able to find some on Craigslist.
You will be fine with +50 offset if you found something FS already. Stock GD sport wheels are 15" with I think +55, the extra 5mm less is inconsequential to either fitment or bearing wear.
I currently have some EP2 sport 15" standard steel wheels fitted to my Jazz, they have been issue free so far, they fit on perfectly, same centre bore hole size.
I can provide a pic if required, but i am very happy with the civic steels on my car.
cheap 15" steel wheels for your 2007 Sport
I just ran across your question, realizing you posted last December.
Discount Tire Direct sells 6x15" steel wheels for 1st Generation Fit Sports, here is a link.
Wheel Products - Discount Tire Direct
They are $55 each, free shipping. Seems like a pretty good deal to me. I buy tires from them frequently, they are knowledgeable and can answer all your questions about offset, etc. They are reliable and fast, very nice to do business with. I have a machine and mount and balance all my own tires for the eight cars I own.
derek244
06-03-2012 02:48 AM
