Honda Fit 2003 Japan - Shifting from 1st gear to 2nd Gear Problem
Hi,
I was trying to figure out whats wrong with my honda fit, i just bought it 2 days ago from the previous owner and it has 84k km mileage. I just noticed today when its shifting from 1st gear to 2nd gear it has a clug sound (its like when you are driving a manual car and you release the clutch early it will drag a bit ) but when its on 2nd gear up to the last gear it shifts perfectly and smoothly with no malicious sound. mine is a 2003 honda fit 1.3 idsi engine automatic transmission. i am thinking maybe the ATF fluid needs to be change. is there anything need to be check aside from the ATF ? thank you in advance. |
solved.
changed ATF to Honda ATF DW-1 |
