Manual Transmission Fill Plug really awkward
Old May 16, 2014 | 08:33 PM
Hondicious's Avatar
Trying to drain my MT but found fill plug is in really awkward position. I can only access using a universal joint (bent at almost 90 degrees) and extension bar. I don't have access to a lift so can't really get and pressure on it.
Old May 16, 2014 | 09:00 PM
Dougr320's Avatar
Your over thinking. Nothing about modern cars is easy. I know I did it with a 3/8drive ratchet and an extension. Don't be a fried to get dirty and scraped knuckles.
Old May 16, 2014 | 09:16 PM
kylerwho's Avatar
spoon fed
i used a 3/8" breaker bar to get it loose.
Old May 16, 2014 | 11:31 PM
13fit's Avatar
break the fill plug loose when you can, then the drain plug. Use the reverse switch up top for filling, and keep the car level with the fill plug removed, the fluid will dribble out when full.
if you remove your air intake and your battery, you can access both plugs from up top if you can reach around the transmission
Old May 17, 2014 | 04:32 AM
Hondicious's Avatar
Thanks! I'm liking the "...remove your air intake and your battery..." idea especially if it allow the bolt to be reached without using a universal joint!
All I'd have to worry about is the radio security code! Guess I'd have to phone the Dealer for that.
Things would be super easy if I'd bought an AT 'cause as you know, they have dipsticks!
Old May 17, 2014 | 10:23 AM
13fit's Avatar
radio code should be inside the glovebox
Old May 18, 2014 | 12:54 PM
Marrk's Avatar
I doubt it.
Try offset box end wrenches, like these:
Sears.com
and ratchet wrenches, like these:
https://www.acwholesalers.com/Klein-...FUVbfgodCpQASQ .
Once the fill plug is out, you'll have a lot of fun pumping the fresh fluid in. Especially with no lift and no professional garage tools. Look at Pep Boys for something like this:
Robot Check Robot Check
Old May 18, 2014 | 04:45 PM
13fit's Avatar
Originally Posted by Marrk
I doubt it.
Sears.com
Robot Check
That is how I did mine, and Im 6feet, beer gut, and fat hands lol
No need to pump at all, remove the reverse switch that is on top next to mounting bracket, and use a small tip funnel.
Screw pumping it.
Doing the reverse switch way also allows you to lower the car to the ground so its level, so that you get a perfectly accurate fill level
Old May 18, 2014 | 07:22 PM
Hondicious's Avatar
...Try offset box end wrenches...
Yes! offset box end wrenches! I never thought of using them! Doh! This has fired me up to have another go!
As to filling, I'll use the gravity method. Attaching some hose to a funnel and snaking the hose down through the engine compartment into the fill hole. Simple and I don't need to pump anything anywhere.
Thanks for jogging my memory!
utsug
Sep 19, 2017 12:50 AM
down_corporal
Jan 26, 2017 08:16 PM
CasualFitOwner
Jul 9, 2012 07:55 PM
zQUEz
Oct 16, 2010 10:11 AM
mozarwasagenius
Apr 20, 2009 05:39 PM
