Code 2647 - Rocker arm actuator stuck on repair.
Hey guys, I'm getting code 2647 today for Rocker Arm Actuator Stuck ON. I had gotten this code before, and it went off on its own the same day so I didn't replace anything. But today it came back on, and my car started acting like it was hitting the rev limiter when I was pulling back into work.
I've read on some other forums that it's not difficult to repair, but those were on K24 CRV/Accord engines. Does anyone know where this sensor is on the L15 head in an 08 Fit base?
Nevermind, I found this thread after doing more Google searching.
https://www.fitfreak.net/forums/cali...ml#post1044618
Gimme posted that its on the front of the head to the right. I'll go back out to my car after work and see if I can find it and hopefully she makes it home.
Sorry no pics, write up yet. I've been hella busy with work projects and otherwise.
But the EXACT location of the sensor is between the intake runners and metal breather tube on the on the air intake. Its partially hidden by the bottom right corner of the plastic engine cover (I removed mine to better get my fat hand down to it).
Google pic for reference.
Z
