WD-40 to unstick a hazard switch?
Old Jan 5, 2015 | 03:15 PM
timmcd's Avatar
2008 Fit Sport Auto:
My hazard switch is super sticky and stuck (in the off position fortunately). I try to push the switch on and it gives just a bit but doesn't depress all the way. Reminds me of when my kid spilled syrup onto his GameCube controller. I've never used syrup (or soft drinks) in my car so I know that's not the culprit.
The dealership says that they would have to remove the dashboard to diagnose the problem, which is kind of spendy. What about squirting some WD-40 into the cracks around the switch, will that hurt anything?
Tim
Old Jan 5, 2015 | 06:11 PM
MTLian's Avatar
I dont think it would break stuff but it might gunk up the switch with dirt since dirt could get stuck in the lubricant. I'd give rubbing or isopropyl alcohol a shot first. It evaporates quickly so it probably wouldn't foul anything up and might clean the sticky substance that is causing the issue
Old Jan 6, 2015 | 12:46 PM
Mister Coffee's Avatar
Agreed.
Better if you could do some disassembly yourself and clean (with alcohol or maybe a cloth dampened with water). WD-40 (which is not a lubricant but a "water displacement" fluid) and lubricants will, as MTLian says, mix with whatever dirt is there and make things worse (probably).
phenoyz
Aug 8, 2013 05:29 AM
StormSurfer
Jul 25, 2011 02:05 PM
Lyon[Nightroad]
May 2, 2010 02:12 PM
OhNineFIT
Sep 3, 2009 12:19 AM
Mugen_Dom
Aug 7, 2007 01:26 PM
