2007 Clutch DIY
Old Jan 20, 2015 | 12:30 AM
Niki4os's Avatar
2007 Clutch DIY
Hello Everyone,
New member here. Owned my fit since 2007 and my OEM clutch finally went. I have officially pulled the transmission, and I will be replacing the clutch tomorrow. (YES, it was a tiny pain in the ass, many parts are awkwardly placed and difficult to reach, but not an impossible job).
I am wondering if anyone has done this themselves, and how they worked the gears afterwards for placement. Any tips or tricks that were successful for you, would be helpful for me. Please share. Thanks in advance
Old Jan 20, 2015 | 12:47 AM
Niki4os's Avatar
NEVER mind, I got it, found reverse and just went from there
Old Jan 20, 2015 | 05:15 AM
s0x's Avatar
s0x
i just did this myself. if you have any questions feel free to email me and ill do my best to help.
Old Jan 20, 2015 | 09:32 AM
Niki4os's Avatar
Awesome. Thanks!
So far all is good. Everything is out.
I busted one bolt on the front transmission mount, but I'm going to drill it out today, put the clutch in, and then start putting things back together.
Everything was removed by hand, so putting it back together will be a little more complicated because I don't think I will be able to torque everything to spec. But im just going to do what I can and go from there.
I definitely need a massage after this. Next thing is suspension, big brakes and then an engine swap. But I needed the clutch badly and I need my summer car on the road before I can start really dismantling this car.
Old Jan 20, 2015 | 09:09 PM
s0x's Avatar
s0x
Awesome. Thanks!
i was able to torque everything back to spec by hand no problem make sure you torque the flywheel and pressure plate back to spec thats super important and it can be difficult but either get the tool to keep it in place or have a friend hold it in place with a pry bar between the teeth of the flywheel. extensions come in handy. the only thing i can remember having trouble torquing back to spec was castle nut on the ball joint I'm pretty sure or maybe the control arm? its a bit hazzy. if you don't have a cheater bar get one cuz that helps a ton on some of the higher torque specs. the only part that we had trouble with was lining the pilot bearing and the casing back up to the engine and then also rear motor mount was a bit of a pain in the ass but i think we put it back after the tranny was in. I'm pretty sure its much easier if you do it with the subframe off (we didn't take it off)
Old Jan 22, 2015 | 12:11 PM
Niki4os's Avatar
Cheater bar has been the life saver for the dismantling. Clutch is in. Transmission is up. Now to finish the rest. I hate that I have a job. It means I'm limited to like an hour or so of actual working on the car. Oh well. Thank goodness the hard part is done. Now I have to purchase a few pieces that broke from being worn out.
Old Jan 27, 2015 | 12:53 PM
hehn's Avatar
I'm contemplating doing this myself. how long did it take you guys from start to finish. I have never done a clutch replacement so I'll likely find someone local that has some experience to help. Any tips for doing this?
Old Jan 28, 2015 | 08:32 AM
cnordt24's Avatar
What kind of clutch did you go with as the replacement.. OEM or aftermarket?
Old Jan 31, 2015 | 10:22 PM
Niki4os's Avatar
I would suggest going slowly, marking each bolt you removed with a number and the place you removed it from with the same number. I have 3 kids at home and business, so the car was down for a week. I could only work on it a few hours a night. I also had an entire two days I could not work on it, as I was waiting for parts. During the dismantle, I replaced the end links and the ball joints. Honda wants you to purchase a Lca, but the lca was fine, the ball joints were worn out.
When you are doing it, I didn't remove the wheel hub, I just pulled the driftshafts out. It was easier that way. I removed the sub frame, only because it made things easier. I also WD40'd every bolt that needed to be removed before I attempted to removed them. It made things easier. I am no mechanic, just a mom and a car enthusiasts but it was still fairly easy. Ratcheting wrenches are your friend, plus a cheater bar, one long and one slightly shorter.
Old Jan 31, 2015 | 10:24 PM
Niki4os's Avatar
I just replaced with an exedy clutch. I plan to do an engine swap, so this was really just to make it to summer.
Old Jan 31, 2015 | 10:26 PM
cnordt24's Avatar
Oh nice, did you stick with OEM or go to stage 1?
Old Feb 1, 2015 | 07:49 PM
Jer Bear's Avatar
thanks for the heads up on which tools to have handy
Bounce
Jul 15, 2017 07:28 PM
AKAgeorge
17
Jan 4, 2017 12:01 AM
trashercan
Sep 25, 2009 03:42 PM
shy34
Aug 31, 2009 03:16 PM
gettinafit
15
May 17, 2006 12:22 AM
