2008 honda fit engine replacement and interchange info needed
Old Jan 13, 2016 | 07:17 PM
Khanj_91's Avatar
I have a 08 honda fit 5 speed. Motor is bad . I have a parts car with good engine but it's an automatic. Will the automatic motor work in the manual car?as far as I can see everything looks similar. Any help will be appreciated.
Old Jan 13, 2016 | 08:20 PM
Hootie's Avatar
At minimum you're going to need to transfer your existing oil pan to the replacement engine due to different shape. An automatic oil pan will not bolt up to the manual transmission if I recall correctly... everything else I believe will exchange.
Old Jan 13, 2016 | 08:33 PM
Khanj_91's Avatar
Thanks for the info. Also the flywheel might be different too.
Old Jan 13, 2016 | 08:41 PM
Hootie's Avatar
Of course.
Manuals will have flywheels, autos will have flexplates.
Old Jan 13, 2016 | 08:56 PM
Khanj_91's Avatar
Any tips? Is it easier to drop both engine and tranny together from the bottom or is it possible to pull the engine from top?
Old Jan 13, 2016 | 09:23 PM
TroyGgd3's Avatar
Are u selling parts from the spare car I need a few interior parts and a rear bumper
Old Jan 13, 2016 | 09:39 PM
Khanj_91's Avatar
Yea I will be parting it out, rear bumper is no good bit you can find it from aftermarket company like keystone or lkq. What do you need from interior?
Old Jan 14, 2016 | 01:32 AM
kylerwho's Avatar
spoon fed
Since you need to transfer over parts I would drop both out the bottom. I pulled a motor from a wrecked fit and pulled it out the top easily.
hondafitblue
17
Feb 11, 2013 12:39 AM
Oofie
Jul 6, 2010 03:04 PM
Fitcious
Nov 17, 2009 07:43 PM
Midnightfit
13
Apr 21, 2008 09:46 PM
jbolanos
Nov 19, 2007 11:52 PM
