Problems resolved. Thank you guys!
Old Feb 23, 2016 | 06:06 PM
Vidiot's Avatar
So I found a 2008 Honda Fit Base on craigslist with 111k miles for $3500. It has a lot of little scratches and dents but is a solid car. I feel like I got a great deal. Anyway, he told me it would cut off when the engine was cold and it probably needed a new catalytic converter. Well after reading through is fine forum I found out that the valves really do need to be adjusted on these things. Turned out that was all that was causing that problem!
Then I started noticing a slight gas smell and lower than expected gas mileage. Again fitfreak comes to my rescue. After spending a few minutes reading here I discover that a loose spark plug will cause that problem and lo and behold you guys saved me once again.
I just wanted to say thank you! This is a great forum!
2008 Fit Base
Attached Thumbnails Problems resolved. Thank you guys!-80-img_1483_4868e5696183956afa578fc2002eb384c4b3d6ff.jpg
Old Feb 24, 2016 | 11:01 AM
Mister Coffee's Avatar
Great that everything worked out so well. Sounds like you got a great deal on that car. It should go for another 111,000 mi.
Old Feb 24, 2016 | 10:10 PM
kylerwho's Avatar
spoon fed
I was not aware kosei made hub caps.
Old Feb 25, 2016 | 08:35 AM
Vidiot's Avatar
Found those wheel covers on eBay for like $25. I'll probably buy some 15" rims at some point but these will get me by until then.
Sandra Dorothy
Dec 28, 2018 09:28 PM
BigArbys
Nov 14, 2014 07:49 PM
$p!@t1027
Feb 23, 2013 10:58 PM
mrpooh
Nov 8, 2012 10:50 AM
jetscream
Jun 18, 2012 09:44 PM
