Diagnosis help: Loud whine when backing up after 4hrs
Old Feb 29, 2016 | 06:34 PM
kwb's Avatar
kwb
When I back up in the mornings, or after the car has sat for a few hours, there is a loud whine that comes from the front of the car. It's different from the break-squeels and only happens in reverse (if I back into the driveway at night, no noise in the morning).
Not sure where to start with this, I assume it's a transmission issue. I guess try a fluid change? It hasn't been many miles since my last... 15-20k.
I'm at 210,000, it's an '07 Base Automatic
THANKS!!
Old Feb 29, 2016 | 06:48 PM
xxryu139xx's Avatar
aside from your typical wind up noise hondas make when they back up?
Old Feb 29, 2016 | 08:53 PM
kwb's Avatar
kwb
Red face
You can hear the normal whirr under this noise. I took a video for the sound... youtube seems the easiest to post it? I can edit and delete if you know a better spot. OH! Forgot, it's all the time now, the morning/4hrish cool down is no longer a condition...
(youtube link - maybe start the volume low... not sure how to describe the sound, it's pretty awful)
Old Feb 29, 2016 | 10:07 PM
xxryu139xx's Avatar
fixed ur youtube link.
sounds like someone sat on a harmonica and it got stuck in their %#4%!
Old Feb 29, 2016 | 10:11 PM
kwb's Avatar
kwb
cool!! THANKS!!!
yeah... the sound is unfortunate....
Old Mar 1, 2016 | 01:23 PM
bargainguy's Avatar
I hear a buzz-saw noise. Sounds like metal on metal.
While it could be the tranny, I'll hazard a guess. Warped rear drums.
Old Mar 1, 2016 | 01:26 PM
dwtaylorpdx's Avatar
Rear drum auto adjusters may be dirty and not working so the shoe is loose.
Old Mar 1, 2016 | 08:16 PM
kwb's Avatar
kwb
Thanks, I'll pop off some tires tonight and see what the breaks look like. Her calipers do have a history of jamming a little and burning through pads... I've tried cleaning them up a few times, maybe it's time to let them go.
Old Mar 1, 2016 | 10:49 PM
geopat's Avatar
Going to agree with the others sounds like some loose in the brakes. More then likely the rears
Old Mar 2, 2016 | 12:54 AM
kwb's Avatar
kwb
So embarrassed
It was the brakes... I had assumed break noise would be consistent in forwards and reverse, but who knows. Here's a pick of the old pads, the rotors didn't feel too awful... I'll inspect the shoes/drums later in the week to make sure the adjustments right. I feel like I just did the breaks.... but we put a lot more miles on the car then I think and the calibers have jammed a few times - burning through pads (I've since rebuilt them) so I don't by the high end pads.... anyways.
Thanks for the advice!!!!
These might be at the end of their life:
They still have 50 miles...
Attached Thumbnails Diagnosis help: Loud whine when backing up after 4hrs-80-lekv3ha_0c66003f27094522e082e25396f7e60e7d7e6d60.jpg
Old Mar 2, 2016 | 02:15 PM
lunch box's Avatar
That picture...
Old Mar 3, 2016 | 09:22 AM
geopat's Avatar
Holy crap those should have been replaced last year
Old Aug 30, 2017 | 01:43 PM
doctor J's Avatar
Had same thing fixed on 2008 Accord. When wear sensor is at the BOTTOM position, then noise will be present at reverse
Martha Campagna
Nov 28, 2018 09:35 PM
Ssainsbu@yahoo.com
May 17, 2016 10:29 PM
domoMKIV
Jan 29, 2016 12:15 PM
MagicGuitar
Oct 13, 2015 05:14 PM
wabaki007
Dec 24, 2014 12:36 AM
