Misfire P1351 & P1353 code, engine intermittent hesitation
Old Jul 11, 2016 | 10:54 PM
Hondarian's Avatar
Does anybody know, coil pack fault if this code appear? Which cylinder?
P1351 - Ignition Coil Control Circuit High Voltage
P1353 - IC Output High/Pulse Detected when GND_Cyl. 3
Attached Thumbnails Misfire P1351 & P1353 code, engine intermittent hesitation-screenshot_2016-07-11-16-39-42.jpeg   Misfire P1351 & P1353 code, engine intermittent hesitation-screenshot_2016-07-11-18-09-58.jpeg   Misfire P1351 & P1353 code, engine intermittent hesitation-screenshot_2016-07-11-18-10-08.jpeg
Old Jul 12, 2016 | 04:09 PM
doctor J's Avatar
Signal line of the coil #3 cylinder is getting power shorted to the signal line. swap coils 2 and 3 and see if the the code follows defective coil.(will indicate cylinder 2 now)
Old Jul 12, 2016 | 09:06 PM
Hondarian's Avatar
thanks for your suggestion
GlennO511
Feb 25, 2023 07:52 AM
Globalksp
Jun 20, 2021 11:36 PM
Donor
Jun 5, 2020 01:19 AM
ltjpunk387
Jan 22, 2016 07:26 PM
craigquakertown
Oct 28, 2015 01:47 PM
