Axle leak from tranny
Old May 1, 2017 | 05:06 PM
Metafit's Avatar
I own a 2007 Honda Fit sport
So during winter... my axle broke from slipping on ice. I bought another axle from O'reilys and installed with seals and everything... the tranny fluid keeps leaking... replaced seal.... it's still leaking after a month... had warranty and got a new axle and new seal.... still leaking?? Mechanic said the axle shaft meets the tranny is wobbly.... not sure exactly what's wrong... it's DRIVER SIDE FRONT AXLE
Old May 1, 2017 | 07:07 PM
xxryu139xx's Avatar
maybe its ur intermediate shaft thats the problem.
Old May 1, 2017 | 07:31 PM
doctor J's Avatar
How many miles on the car? If side gear in differential wore out differential bore due to the spinning the lot of wobble will be detected in the axle near inboard joint (very common on first generation FWD Toyotas)
Try Honda OEM seal it is more flexible compared to aftermarket.
Old May 2, 2017 | 02:23 PM
Metafit's Avatar
I was thinking same too. I'm gonna see if a Honda seal wil do the job.. I am curious to see... would an oreiliy axle be bad compared to oem? I'm sure they are like identical...
My transmission shift fines... everything about it is still really good
It has 114,000 miles
Old May 2, 2017 | 09:24 PM
doctor J's Avatar
The only critical will be a nick or burr on the surface of diameter that touches the seal.
If no damage there, coat this diameter with wheel bearing or similar grease (#1 or #2 thickness) before installing
howardmitch
Aug 4, 2017 08:02 PM
skytree
May 18, 2015 12:45 AM
413FIT
Aug 30, 2009 07:57 PM
petwhookie
14
Apr 30, 2008 08:25 AM
WaterWatcher
May 4, 2005 11:16 AM
