2007 Fit Clutch Noise Identification
Old Nov 29, 2017 | 11:23 AM
omega505's Avatar
My Fit has developed some chatter when in neutral and is getting progressively worse.
I figured it might be the release bearing, however it does not match what I have read about diagnosing a bad release bearing.
Basically the chatter completely disappears when I depress the clutch. I feel no restriction or pulse in the clutch pedal.All shifts are clean and there is no slipping issues. Just a increasingly loud chatter in neutral.
Any thoughts or ideas on how to narrow down the real issue?
Could it be a simple as an adjustment to the linkage?
Thanks in advance
Old Nov 29, 2017 | 11:32 AM
GAFIT's Avatar
Throw out bearing noise. I'm surprised you haven't had it happen sooner. Ours has it for the second time.
Only fix is a new throw out bearing. Due to the work involved it makes sense to replace the entire clutch at the same time.
Old Nov 29, 2017 | 11:38 AM
omega505's Avatar
Made the mistake of taking it to the dealer 2 years ago for a new clutch, but I always wondered if they had replaced all the bearings at that time. As it always had a slight noise after that fix. About 20k miles since that clutch replacement.
To your knowledge will the throw-out bearing totally fail and leave me stranded or it mostly an annoyance until I can budget for this fix?
Old Nov 29, 2017 | 11:42 AM
GAFIT's Avatar
We ran ours with the noise for about 30k miles the first time. Been running it with the noise for about 10k for the second time now.
I would probably get some miles on the second clutch before replacing. The whole assembly from Exedy is about $140USD on amazon. It's the labor that hurts the budget.
Old Nov 29, 2017 | 11:56 AM
omega505's Avatar
Thanks for your quick reply. I hate to take it in for the clutch so soon unless it presents with other issues.
At the same time this has been going on there was a companion noise of a bad rattle when driving, but I finally found the cause of that which was a broken mount on the clam shell style heat shield for the exhaust. Easy fix just clamped it down with a large metal hose clamp.
Guess this heat shield rattle is also a very common issue.
TroyGgd3
Oct 26, 2016 08:30 AM
carrier
Jul 1, 2016 07:43 PM
viperpit07
Nov 8, 2015 09:52 PM
GBR
Jun 12, 2015 08:18 PM
trinisir
May 11, 2015 08:47 AM
