Lifting my fit
Old Jul 25, 2018 | 07:30 AM
Steveo7's Avatar
Lifting my fit
Hello everyone. This is my first post on here. I’m sorry if this is a dumb question. I did try searching however I am not the most tech savvy person.
I am looking to lift my fit some. I found some cool spacers for the rear but what can I do in the front? Does anyone kno if different springs will work? Say lowering springs for a crv or stock accord/ civic springs
Old Jul 25, 2018 | 12:36 PM
DaGou's Avatar
Are you converting to 4X4 as well? Just trying to figure why you want to lift a Fit. You want a higher center of gravity so it handles like crap?
Old Jul 25, 2018 | 12:46 PM
Steveo7's Avatar
Looking to put a certain set of rims and tires on it. Need to go up about 2”
Old Jul 25, 2018 | 04:06 PM
knope's Avatar
lmao
Old Jul 25, 2018 | 04:07 PM
GolNat's Avatar
You can get custom springs made from Swift or Ground Control but your shock is only so long.
A set of coil overs might be able to go higher then stock but I don't think so as most have them have shortened springs and shock bodies. Maybe you can email someone about it.
BC Racing
K Sport
Tein
Old Jul 25, 2018 | 05:55 PM
Steveo7's Avatar
Thank u for the response. I will look into the customer springs. I didn’t think coil overs would do it either. Would make the ride stiffer but not sure about higher
Old Jul 25, 2018 | 06:14 PM
knope's Avatar
are you looking to enter a donk competition?
this thread may help
Old Jul 25, 2018 | 10:35 PM
DaGou's Avatar
Be the first Fit to run 24s.
Old Jul 26, 2018 | 06:28 AM
Steveo7's Avatar
Lol at the donk competition. There 16’s with a 205 55 16 tire with a 25 offset. They rub just a little in the rear. That’s what I want to go up about 1.5-2”
Old Jul 26, 2018 | 07:20 AM
knope's Avatar
What about a lower profile tire? Or stretching a thinner tire if the rub is in the corners?
edit: how/where is it rubbing? Can you snap a pick or 2?
Old Jul 26, 2018 | 08:12 AM
Steveo7's Avatar
My wife surprised me with the rims and tires and of course they are non returnable. The rub the outer quarter. I’m sure I can just have the fenders rolled. However this is my everyday daily driver just don’t want to go crazy modifying it.
Old Jul 26, 2018 | 08:26 AM
GolNat's Avatar
Does it only rub on dips? If so stiffer springs would help.
Old Jul 26, 2018 | 09:11 AM
Steveo7's Avatar
Yes mainly dips but im also sure if input someone in th backseat or something with decent weight in the back it will rub.
Old Jul 26, 2018 | 09:36 AM
DaGou's Avatar
I am certain that getting a slight roll on your rear fenders would be a much less intrusive mod than raising your suspension 2".
Old Jul 26, 2018 | 10:09 AM
Steveo7's Avatar
I’ll check my local body shops about getting the fenders rolled.
kingkelly
Oct 7, 2023 10:45 AM
Regdog77
Jul 25, 2018 10:23 PM
FitGD4
Oct 4, 2013 08:58 PM
runbikerun
Nov 11, 2009 06:44 PM
dank24
Dec 4, 2007 02:54 PM
