07 Can't Get it Started
Sorry this post is my first. I dont know where else to turn lol
Searched the forum heavily and havent been able to find a solution to my issue. Here's what im dealing with: Have owned my 2007 Fit for about 30k with no issues. Currently @ 117k. Drove the car around with no issue yesterday. Even changed the oil. Parked it after work, came out this morning and it wouldnt start... Car turns over fine it just wont fire. Checked the immobilizer. Operating as it should with no issue (from what I can tell) After a brief troubleshooting session I came to the conclusion it was most likely a dead fuel pump. - Couldn't smell fuel after repeatedly trying to start it - Couldn't hear a fuel pump kick on - Accessed the fuel pump and disconnected the lines. Turned the car on to see if i would spray fuel in a bottle and nothing. - Fuse was good, relay clicked, etc... Ultimately decided to buy a new fuel pump ($60). Installed it and still can't get the car to fire. What am I missing... Thanks in advance |
stupid question? did you try to jumpstart it?
Is the CEL on? |
No CEL and yes I tried to jump it.
Have you tried pulling a spark plug out, re-connect the coil and see if you get spark when turning the key? Will need two people.
Is check engine light on with engine off key on?
Originally Posted by BLP
(Post 1409336)
Might be worth a shot, though I'm not sure how you could've tripped it:
Unplug the crankshaft sensor and see if it starts. A bad one can cause a crank no start condition.
Originally Posted by doctor J
(Post 1409388)
Borrowed my friends OBD Scanner and it did throw P0302 cylinder 2 misfire |
Originally Posted by GolNat
(Post 1409411)
Originally Posted by upallnight
(Post 1409402)
But did you check for power at the fuel pump connector? Did you check for Ground at the connector? Fuel pump won't run if there is no power or ground.
(Post 1409493)
Fuel pump is running
(Post 1409495)
I'm assuming now that the fuel pump is running you need to check for spark at the plugs and an injection pulse at the injectors.
Does any one else find it weird (and highly unlikely) i would lose a fuel pump and a couple ignition coils at the same time? |
That is weird and highly unlikely. Loosing more than one coil pack is odd but also a fuel pump!!! Honda fuel pumps are very robust! I’m wondering if you have another issue and it’s not these isolated things. |
(Post 1409525)
How did you test the immobilizer? I believe it will still allow the car to turn over but cuts fuel and spark.
It also can have a code and not show a CEL. In the service manual low key fob voltage could be an issue. |
(Post 1409529)
It also can have a code and not show a CEL. In the service manual low key fob voltage could be an issue. Only code was P0302 but ive never had a CEL so im not convinced its relevant to my current issues. Car didnt have a service manual so I dont have one. Only have 1 key for it. |
did you find the problem? my mechanic said under dash fuse box bad and rewired something with a jumper.
Originally Posted by nature boy
(Post 1459019)
| All times are GMT -4. The time now is 01:54 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
