Did my transmission just die?
Old Dec 24, 2018 | 05:57 PM
gfrobe's Avatar
I have a 2007 Fit with 165k miles and no history of transmission problems. Tonight I went to back out of my driveway, felt a hard jolt or thud underneath and the car was then unable to move. When I shift into drive and step on the gas, there is a loud whining noise along with a steady loud knocking underneath but the car will not move. I pushed the car down to the bottom of the driveway, which is on a slope, and even with the car in park at the bottom, it continues to roll. So it's now sitting at bottom of my driveway with the emergency break on to keep it from rolling into the woods..
I plan to have it towed to Honda this week but wondering if my transmission is indeed shot. Wife drove the car earlier today with no transmission symptoms whatsoever.
Any ideas what this could be?
Thanks.
Old Dec 24, 2018 | 07:09 PM
RicerX's Avatar
Sounds like an axle failed.
Old Dec 24, 2018 | 07:17 PM
gfrobe's Avatar
Thanks for the reply. Just been searching the board and googling a bit and also suspect that it could be an axle. Given the age of car, I'll probably tow to local mechanic rather than Honda as also reading that aftermarket parts would be better value in my situation.
Old Dec 24, 2018 | 08:31 PM
ezone's Avatar
An axle probably broke in half, Common issue especially in the salt belt.. I'd urge you to consider replacing both if they are still original.
I replaced both on my GFs 07 Fit at about 210,000 miles or so....before one broke and stranded her 2.5 hours from home
Old Dec 24, 2018 | 09:13 PM
gfrobe's Avatar
Thanks ezone. Can I ask how much it cost you to replace both? And did you to it yourself or have a mechanic do it?
Old Dec 24, 2018 | 09:59 PM
ezone's Avatar
I got the axles from a local parts store. Don't remember the prices now, it was a good 2 years ago.
I DIY everything because I do it for a living
Old Dec 25, 2018 | 07:51 AM
doctor J's Avatar
Can anyione post a picture of tan axle at the failing point? Cannot believe that only the rust caused this failure! I saw few broken steering knuckles (on the junk yard) after collision; they break below the strut mounting bolts (at H-cross section)
Old Dec 25, 2018 | 11:47 AM
MTLian's Avatar
If the CV joint boot gets compromised and crud gets in there I would think i would think it would fail from friction and wear. Also the axles are relatively thin. I can totally see rust eat away at an axle until it becomes brittle and fails.
Old Dec 25, 2018 | 12:18 PM
ezone's Avatar
Sorry I dont have pics of mine nor any pics from customers cars
The original axle will break underneath the rubber damper located somewhere near the middle of each shaft. That small chunk of rubber traps water and salt which slowly eats away at the steel shaft until its integrity is compromised.
The aftermarket replacement axles I installed did not have the dampers.
Old Dec 25, 2018 | 12:33 PM
ezone's Avatar
GIS for broken cv axle:
Old Dec 25, 2018 | 01:16 PM
doctor J's Avatar
Thank you!
Old Sep 30, 2019 | 09:53 AM
okey0's Avatar
DANG this just happened to me in the parking lot where I work. Should have have just replaced it on my own in the comfort and cheapness of my garage. Quoted $450 to fix (about $80 of that is for towing)
howardmitch
Aug 4, 2017 08:02 PM
hansclap
Jun 12, 2016 02:01 PM
Andrei8
Oct 19, 2015 10:48 PM
SLeith007
Jan 29, 2015 02:00 PM
FitPilot
Mar 24, 2014 05:35 PM
