baterry light goes on and off after new altenator and battery
Old Jan 29, 2019 | 04:55 PM
crunchie's Avatar
Question baterry light goes on and off after new altenator and battery
well I sure hope someone can suggest a cause for my problem-a few months ago I was told my alternator was pooched-so I had a new one installed and at the same time a new belt- its run well until a few days ago when the baterry light came on-I got it back home by turning all the accessories of i.e-fan etc. when I got home turned it off and the battery was dead-thru it on the charger for a few hours and it was fine-NO battery light warning--drove all day today lots of stops and starts, then on my way home the battery light came on again-took it to a place that just deals in batteries the fellow checked it said it was done-so I bought a new one, ran it for an hour or so battery light tuurned on agin? --turhed the car off battery light comes on -a a min. or two light comes back on?? I retsrted it a half dozen times with the same result-would anyone hazard to guess what could be the cause or causes? thnx a lot guys!
Old Jan 29, 2019 | 05:38 PM
doctor J's Avatar
Check the alternator fuse (80 amps) near positive battery terminal
I afraid the replacement alternator is toast (unless it's reman by Honda)
Old Jan 29, 2019 | 05:42 PM
crunchie's Avatar
thanks for the quick reply- its weird it ran all day with no issue with the battery light- I am going to check that fuse as well as the connections of the altenator- A BIG THANKS AGAIN-DOCTOR! <btw-it is a Honda alt.>
Old Jan 29, 2019 | 09:18 PM
doctor J's Avatar
Hook up voltmeter to the battery terminals; at idle in park /neutral it should read about 14 volt with engine on.
Also try to move "B" wire attached to the alternator via 10 mm nut
Old Jan 29, 2019 | 09:42 PM
VictorHash's Avatar
Doctor j is a real American doctor.
Old Jan 30, 2019 | 01:35 PM
crunchie's Avatar
Well Dr. J you were correct, the rebuilt alt. was toast!, I ended up with a credit, and a new alt. with a 6 month guarantee labour inclusive. Let me thank you for all your suggestions which I did perform ,but you were right on form the beginning-thnx crunchie
Old Jan 30, 2019 | 01:43 PM
doctor J's Avatar
Red face
This makes me worry about the quality of rebuilt parts in general. 99% of rebuilt alternators are sandblasted, painted nicely, placed in the cool looking box and resold in the chain stores by hot-dog looking ladies with 2 inch manicure. Oops, forgot to add, they got $3 brushes replaced using 2000 W solder gun, occasionally new $3 Alibaba bearings are installed too with the help of 5 LB sledge!
Old Jan 30, 2019 | 05:52 PM
Carbuff2's Avatar
^^^ Which is why I now have a local alternator shop rebuild my bad alternators (and starters)
Luckily I have other cars to use while they do the job. It only takes 'em a day...in by 4, out the next afternoon.
Old Jan 30, 2019 | 08:31 PM
doctor J's Avatar
On my past cars I've done alternators [overhaul] myself; 87 Camry was the easiest!
Old Jan 31, 2019 | 10:35 AM
Carbuff2's Avatar
Overhaul is easy, but I don't have the facilities needed for testing.
That's where the auto electric shop earns its money.
They KNOW the failure modes for differing models...a 'breadth of experience'. EX: some alternators need bearings replaced. AND they know how long brushes last.
(They get the wholesale rate for parts and that makes up for the test cost.)
Old Jan 31, 2019 | 03:31 PM
doctor J's Avatar
For modular type ND generator about a third of the problems contributed to bad voltage regulator
stevedeleeuw
Canada Fit Forums & Clubs
Sep 29, 2017 12:25 AM
scootley
Dec 6, 2015 09:46 PM
zader
Jan 26, 2014 03:48 PM
blaaaackfit
Jun 4, 2013 04:41 PM
k3uns
Jun 13, 2012 01:00 PM
