2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
Asian vs USDM rear bumper.?
Old Feb 15, 2010 | 01:56 PM
ej96hatch's Avatar
Is the Asian/Japanese GE rear bumper different than the USDM GE rear bumper? I found a nice looking piece that I would like to get if it will fit! Hell, it's cheap enough that if it doesn't fit, it could maybe be modified to fit the usdm rear bumper!
Thanks in advance!
Old Feb 15, 2010 | 10:55 PM
accordguyintake's Avatar
ours is extended, it's longer.
Old Feb 16, 2010 | 09:47 AM
ej96hatch's Avatar
Would the difference in length affect the rear lip part at all?
Old Feb 16, 2010 | 02:27 PM
i think so... since the rear lip wraps around, i believe the style of the bumper is different too, not fully sure though
Old Feb 16, 2010 | 06:58 PM
ej96hatch's Avatar
I understand! Do you think the middle of the lower rear bumper have the same specs? The part where the little diffuser things are!
Old Apr 8, 2010 | 11:38 PM
blackndecker's Avatar
Did you ever find out more about the rear bumper difference?
Old Apr 9, 2010 | 01:04 AM
kloopon's Avatar
The USDM version is longer, and its diffuser looks like Spoon's and as for the front bumper, it's totally different.
Mine for example, the Asian version( or i should call it JDM?). Here, we have 2 variations..which is Jazz GE 8 type S and RS.
Type S does not come with airbag, and no paddle shift, and different bodykit.
Type RS has it all, airbags, paddle shift, sideskirts, and rear diffuser.
Old Apr 9, 2010 | 08:55 AM
Thanks for the reply.
Has anyone tried to mount up a JDM rear bumper/body kit to the US spec Fit?
Old Apr 9, 2010 | 10:58 AM
FITMugen's Avatar
AJ-R is already done the USDM to JDM GE8 conversion.
https://www.fitfreak.net/forums/2nd-...oject-ge8.html
Old Apr 9, 2010 | 07:06 PM
ej96hatch's Avatar
I haven't had the chance to look into it further! I will be doing some research shortly! I will post what I find out! I may just order it up and see what the fitment is like!
Old May 2, 2010 | 10:52 PM
lilaznphatboy's Avatar
ive had the JDM rear bumper on my GE since nov. all you had to do was remove the rear bumper and rear crash bar and you are good. but i needed the little safety so i had my fabricator cut mine down to size, weld everything back together so now i have one... i also had to cut off one of the hangers for the exhaust because its attached to the crash bar and weld it in a different stop cuz it wasn't going to give enough clearance...ill post pics on my thread soon on my JDM front and rear conversion
Old Sep 8, 2011 | 10:05 PM
Not_as_Fit's Avatar
will that work with the front to?
stembridge
Feb 22, 2020 12:01 PM
Ciggy
28
Oct 13, 2012 12:07 PM
alexfree05
May 26, 2008 08:47 AM
pgreene
Jan 23, 2008 08:30 PM
