Idea: installing permanent bluetooth speakerphone?
Old Jun 24, 2009 | 11:33 PM
pgethea's Avatar
Hi everyone,
relatively new 09 Fit owner here, I have enjoyed these forums since I got my Base Manual Fit in May. So far I have installed the Homelink Maplights in my new Fit based on information from this site. The only other thing I really wish my Fit had was Bluetooth for my phone. I recently picked up a $30 Motorola T305 Bluetooth speaker phone, and I must say, it works quite well.
So this got me thinking: why couldn't I take the thing apart and somehow install it permanently into the fit. Maybe in the visor or near the map lights somewhere?
All I need is 12 Volt power, which I have from the maplight, a spot to put the microphone and speaker, and a CAll button for answering the phone.
Maybe I could even hook it up to the stereo through the aux port so the sound would come out of the car speakers?
Anyone have any ideas? has anyone tried this?
I am considering buying another T305 and opening it up and seeing if I can access the speaker, microphone and buttons...
One complication is that the T305 has one feature I don't like: it turns off every 30 minutes if it is not in use, so when you get to your car you have to turn it on every time. So I would probably need a way to do to turn it on too, or figure out a way to bypass the auto off mode.
Please reply with ideas/suggestions/etc.
Old Jun 25, 2009 | 11:13 PM
MetalFit630's Avatar
Theres a few options out there for you. I've installed a number of devices from Parrot. They start at about $150 and go up from there. The have a mic that I usually run to the top of the A pillar, a control/display part that goes wherever you can fit it, and a hide away module for the brains. What you do is physically cut the spear wires on the harness and hardwire the brain inbetween the wires. When you get a call, it cuts off the speakers regardless of what you are listening to and routes the call through it.
It sounds great for both sides, and will automatically connect everytime you turn on the car without taking thep hone out of your pocket. It also allows you to do voice dialing and search through your contacts on the display unit.
If I weren't doing an aftermarket deck with built in Bluetooth, I'd do one of these. It is ten times better than any other option in my opinion.
Old Jul 25, 2009 | 09:36 AM
FitIsGoNY's Avatar
I have to agree, the Parrot is the way to go. I have one installed in my Fit and love it. I am in the car about2.5 to 3 hours a day, so I tend to talk on the phone a bit. Go the better route and get the Parrot. No need to mute music, no need to switch inputs, it does everything for you.
Old Jul 25, 2009 | 01:35 PM
gynosis's Avatar
I have the Parrot Mki9200i and I love it!
Old Jan 23, 2010 | 08:48 PM
LLLC1393's Avatar
So does installation of a Parrot unit require a wiring harness for the radio? I don't see one listed on Crutchfield. I'm not much of a DIYer but could probably do a harness plug in. I hate paying the audio installer, but the Parrot seems like a great solution. Please share your installation details. Thanks!
Old Feb 18, 2010 | 05:12 PM
cFoo's Avatar
One more vote for the Parrot option. It's cheaper than Honda's HFL kit and it gives you a nice caller ID display. The Mki series is awesome with the steering wheel mount remote.
Do a search for "Honda BlueTooth harness" on Amazon and you'll find the Crutchfield cable. It's about $30 and will make your installation a walk in the park.
Old Feb 18, 2010 | 09:15 PM
LLLC1393's Avatar
I will have to call Crutchfield to be sure I get the right cable. Thanks for the tip.
Old Feb 18, 2010 | 10:14 PM
Daemione's Avatar
Plenty of bluetooth phone options in aftermarket head units . . . A parrot or the like may be $150 or so - but a few dollars more gets you a headunit with much improved sound quality, upgrade ability, AND bluetooth phone.
Old Feb 19, 2010 | 12:59 AM
cFoo's Avatar
It would have been nice to see a list of HU that "fit" before I went ahead with the Parrot. I picked it simply because I don't know anything about HU or which one would fit nicely in the Fit.
Old Feb 22, 2010 | 06:09 AM
LLLC1393's Avatar
If you change head units, can you still use the oem iPod cable? That is a nice feature.
exl500
Mar 1, 2015 09:50 AM
trashercan
Dec 7, 2014 09:44 PM
NotMyName
Aug 18, 2014 09:43 PM
StinklePink
Nov 13, 2013 05:16 PM
GlennQuagmire
Jun 8, 2009 08:15 PM
