Steering Wheel Audio Controls Installed (sorry, no pictures)
Old Sep 10, 2009 | 10:08 PM
Clunker's Avatar
2009 Fit Sport, non-nav.
1. I purchased factory steering wheel audio control and cruise control switches, p/n 36770-TK6-A41, (about $115) and installed in steering wheel (steering wheel removal required) ... this entailed removing the cruise control switch and replaced with combined cruise control/audio control switches.
2. The new switches have wires all in same locations and colors as old cruise control switch wires, except there are two new wires for the audio controls (and hands free telephone, which I ignored).
3. The audio control buttons didn't work just by plugging in new switch ...
3. I removed the cable reel and found that the two new wires from the audio controls do in fact pass through the cable reel to pins on the back of the cable reel (pins 3 and 4; sorry, no pictures).
4. I removed and looked at the radio and found that the 24 pin connector into the radio does have all 24 pins, none were missing, so I was optimistic the remote audio control feature was present
5. I somehow deduced that Pins 5 and 16 on radio harness are for the audio remote wires.
6. I dug into my parts bin, and found two pins that were a match for the cable reel connector (actually, I cannibalized pins from old cruise control switch that I'd removed), and I found two pins that matched the audio head unit connector (mine were from a late model honda CR-V connector).
7. I fabricated a harness between cable reel and head unit (2 wires)...and plugged the pins into the existing harnesses
8. Steering wheel audio controls work!
ET
Old Sep 10, 2009 | 11:28 PM
interestingstuff's Avatar
Old Sep 10, 2009 | 11:35 PM
mike2100's Avatar
Cool good job.
It's hard to understand what you mean with the wires though. Are you saying that the extra 2 wires between the steering wheel and stereo harness already exist?
And what do you mean by cable reel?
Old Sep 10, 2009 | 11:57 PM
tobey457's Avatar
Originally Posted by mike2100
Cool good job.
The cable reel looks like a spool of computer ribbon (kinda), and it feeds various electrical items in the steering wheel. I made the mistake of uncoiling one by mistake on my Sti... not fun.
Here's where I'm unclear - are you tapping into wires 5/16 from the head unit? You said the plug was full, so I'm assuming those wires are there and they go to something. Trying to figure out why you needed two pins for the radio side of the harness, and where you put them - I understand the cable reel side of the newly made harness...
Seems pretty straightforward - essentially everything is 'plug and play' except for two wires running from the wheel ribbon to the radio, but I'd like to see pics. I also wonder if the steering wheel controls from other models (like the Si) would work?
Old Sep 11, 2009 | 12:39 AM
goredox's Avatar
Good work Clunker! Thanks for sharing the info!
Sorry if I should have put in one of the other threads.
I guessing he figured out the pin 5 and 16 from https://www.fitfreak.net/forums/2nd-...-non-navi.html
or page 23-12 of the manual.
I assume what he saw was that all 24 pins exist in the radio side of the connector.
I have a 2009 Fit base, so I looked up part numbers for the cable reel. It connects the wires in the moving wheel to the stationary column.
09 Fit Navi 77900-TA0-C21
09 Fit Sport 77900-TK6-A01
09 Fit Base 77900-TK6-A11
I'm hoping that my base cable reel has all the wires like the sport did.
Now I'm wondering if the Gauge Control Module is the same part with different part number for the base and sport. It controls cruise control and base doesn't come with cruise.
Old Sep 11, 2009 | 12:58 AM
rosswond's Avatar
It shouldn't matter. AU model VTi has the steering wheel audio controls and no cruise.
Old Sep 11, 2009 | 07:40 AM
Clunker's Avatar
My pin numbers are from an electronic service manual...they don't match Steering Wheel Audio Controls POSSIBLE on non-navi! because his "A, B, C, & D" pins are my pins 12, 1, 24, & 13. The colors match up with his, though.
Audio Connector A
1 red ?
2 x
3 blu k-line
4 grn scty
5 wht audio remote
6 orn rr r-
7 blu rr r+
8 x
9 x
10 brn rr l-
11 gry rr l+
12 blk grd
13 gry ill+
14 orn acc
15 blu vss
16 pnk remote
17 x
18 red fr r-
19 brn fr r+
20 x
21 x
22 lt grn fr l-
23 lt blu fr l+
24 pnk b+
[IMG]file:///C:/DOCUME%7E1/DEBRAA%7E1.RED/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG]
Old Sep 11, 2009 | 10:09 PM
Clunker's Avatar
The two wires that are needed between the steering wheel and the audio unit do not already exist (those are the ones I had to install them). But, the cable reel has 20 pins on both the front side and the back side. My original steering wheel had leads for the horn, paddle shifters, cruise control, and illumination (airbag is a separate connector). When I installed the audio buttons, it had connections to two more of the pins on the front (the wires to these pins were grn/red and brn). I used an ohmmeter to find that these pins had continuity to two pins on the back side of the cable reel. However, the harness that plugged into the back side of the cable reel did not have wires at those pin locations. Nor did the harness that plugged into the back of the radio have wires that would have connected to the audio remote control pins. I made a two wire harness that went into the back side of the cable reel and into the main harness of the radio.
The cable reel is what Honda calls it, some other people call it the clock spring. It's a donut shaped spool that lets electrical connections pass through the steering wheel as it turns, without breaking the wires as they wind around.
Old Sep 11, 2009 | 10:19 PM
Clunker's Avatar
to Tobey457: The radio itself has a main connector, 24 pins are all there. However, the harness connector that plugs into my radio does not have 24 wires. It looks exactly like the pictures posted by thebluepotato, and has only 16 wires. 8 spaces were blank. I plugged the two new wires into that harness connector, one between the orange wire and the green wire (top row), and the second between the blue wire and a blank space (bottom row). Like I said, my Fit is a 2009 Sport non-navi, I'll also mention it's an automatic (U.S.)
Old Dec 16, 2009 | 02:51 PM
umop-apisdn's Avatar
ET
So, just to clarify, all one needs to do this is the audio/cc unit and the pins on the radio end? Pins on the cable reel end can be cannibalized from the old CC assembly? I dunno how I will get those pins. Every junkyard i've ever dealt with will either sell the entire cabin harness or none of it.
Old Dec 31, 2009 | 08:23 AM
marche's Avatar
Hi,
im not exactly sure how you did yours, but this is how my steering wheel looks like:
did you remove the center nut, and removed the steering altogether? The manual says that I need a commercially available steering wheel puller..
I can see the harness down there, but not sure how I am going to attach the steering controls there. If I buy the part listed on this thread, will I get some kind of extra cables?
Old Dec 31, 2009 | 10:28 AM
dewthedew's Avatar
when I installed my momo wheel I took that nut off and just pulled really hard on the wheel and prayed that I wouldnt smash my face
Old Dec 31, 2009 | 04:29 PM
rosswond's Avatar
Originally Posted by marche
Hi,
You should be able to get a steering wheel puller at any auto accessories store. They just have two bolts that fit into holes in the spokes (need ones with the right thread, but any two bolts of the same length and the correct thread will work) a bolt that pushes on the column. You tighten it up and bang! off it comes.
You could make one. All you need is a thick piece of steel with a central threaded hole ( or a nut welded underneath) and two holes spaced to match the holes in the steering wheel. Thread sizes will depend on what bolts/nuts you have available. I suggest 10mm (5/16") or bigger for the central one. Keep them as short as possible to stop them bending. Remember that the holes in the steering wheel are metric but the central hole in your puller doesn't have to be.
I can see two bolt holes in your pics either side of the column nut that look likely candidates for the puller. Just be sure they are a part of the hub and sturdy enough to do the job.
If you know what you are doing, that should be enough for you to figure it out. If not, just buy one.
Oh, and you seem to have already removed the airbag, and you were oviously careful enough not to set it off be cause you wrote the above
Old Jan 1, 2010 | 06:44 AM
Clunker's Avatar
to marche: I removed the center nut, and removed the steering wheel without the need for a puller. I sort of wiggled it and it came loose without great effort. You do have to remove the steering wheel, and then disassemble the front trim and rear cover to remove the blank piece on the left side, and the cruise control switch on the right side. The new switch harness (mine was p/n 36770-TK6-A41, automatic/sport) is a combination switch, with the audio controls and the cruise controls all in one harness. They plug right into the cable reel. However, look at the harness connector that plugs into cable reel. You will see that the new one has more wires and pins, as it has wires for everything the old switch harness had, plus more wires from the audio switches (and also another connector, I think it's for a bluetooth option). Therefore, the real difficulty was getting wires connected from the audio control switches to the radio. I had to fabricate that two-wire harness, to connect between the back of the cable reel and the back of the radio, as mentioned in my first post. You do not get that part with the part from Honda, you have to make and install it yourself.
Old Jan 6, 2010 | 10:05 PM
marche's Avatar
hi clunker, do you think you can take a picture of what it looks like now? I cant find a picture of that combined audio cruise control assembly anywhere! also, does the cruise control work? Mine doesnt have cruise control by default, but I think I need another part for that to work....
Old Jan 7, 2010 | 12:48 AM
JJIN's Avatar
if you need pins for the harness i found this online http://www.installer.com/item/displa...php?it=71-1729 this might help a bit in your endeavors for audio controls.
would you please make a DYI once you complete your install!
Old Jan 7, 2010 | 09:48 PM
marche's Avatar
hmm. thanks! but I'll try to find a way to make somekind of harness first. I havent actually opened up the steering wheel yet. but will do soon enough.
Old Jan 19, 2010 | 08:37 AM
Now that someone has found the radio side pins I want to do this. Do the controls in any way allow scrolling/selecting/playing files on the USB input?
Old Feb 4, 2010 | 05:12 PM
polokid69's Avatar
I recently bought the 36770-TK6-A41 and hooked it up in my sport. I took to local shop to do the wiring and they had me go out and get this module connector PACC for $69.99. They were able to get everything to work except for the mode button. The way I read most of these posts was it just took a couple wires and not this module. If it only needed the wires maybe I need to take it back with the wiring instructions from here so they can get the mode button to work. Any ideas ?
Old Feb 5, 2010 | 08:55 PM
benmunger's Avatar
This is what I did...
It fully controls an ipod iphone or itouch
