Focal 165V1 install help?
Old May 24, 2010 | 12:16 AM
NipponFit's Avatar
I'm looking to install the Focal 165V1 into the GE6 in a few days here.
Anyone have any hints/tips to install these things?
I've been hearing that yo need spacers, but I've also read that you can reuse the factory mounts with a little modification.
Old May 24, 2010 | 07:33 AM
Fit4Spl's Avatar
My JBL GTI series midbass is pretty deep also. You can look on my build topic and see I used a 3/4" spacer made of MDF to put the midbass in a better spot so as to not hit the window. You will probably need at least a 1/2" spacer if not a 3/4" one the mounting depth on your midbass is the same from what I can find as mine. There was room behind mine after doing a 3/4" spacer but I like to leave room behind rather than just cut it way too close.
Old May 24, 2010 | 08:26 AM
NipponFit's Avatar
Thanks for the reply. Could you tell me the model of your speakers? I would like to know the mounting depth on them to compare numbers.
Mine are 71.3mm (converted it says 2.80 inches)
Old May 24, 2010 | 04:05 PM
Fit4Spl's Avatar
Jbl c608gti mkii
Old May 24, 2010 | 11:10 PM
NipponFit's Avatar
Installed. Will take pictures when I install the tweeter as well.
actually used the oem bracket as I couldn't find any spacers for 165mm speaker in japan (all of them were either 16cm or 17cm) and i don't have the equipment to cut some out.
Old Jun 19, 2010 | 07:50 PM
ck42's Avatar
Any pictures?
Old Jul 21, 2010 | 07:49 PM
NipponFit's Avatar
sorry for the late reply. i don't go on the forum that often.
https://www.fitfreak.net/forums/2nd-...ry-mounts.html
sloganmartin
Sep 22, 2012 03:33 PM
melv0
May 20, 2012 11:56 AM
jnesselroad
14
Mar 5, 2012 05:24 PM
UN_FIT
Jan 30, 2011 08:55 PM
Alex T.
Nov 26, 2010 05:10 PM
