Installing Auto Dimming Mirror?
Old Nov 22, 2010 | 04:58 PM
Fitfan46's Avatar
I recently got a auto dimming mirror for my '09 fit sport. I can't seem to figure out how to remove the mirror(well i can i just don't want to break anything) correctly. So my first question is how do you remove the mirror without breaking anything? Also, which wire do i tap into for power for the mirror?
Thanks
Fitfan
Old Nov 23, 2010 | 04:54 AM
Black3sr's Avatar
Insert a small screwdriver in the slots on either side to release the tabs then pull towards rear.
No wires up there so you may have to snake one back to the dome light might work?
I find with my dark tint on hatch I have no problem at night.
Old Nov 24, 2010 | 05:52 PM
Fitfan46's Avatar
Thanks for the help, between your advice and a diy if figured it out without breaking anything ! I still have to wire it up though. Is the solid purple wire(outlined in red in the pic) the right wire to tap into for switched power?
Thanks
Fitfan
Old Nov 25, 2010 | 05:07 AM
Black3sr's Avatar
The purple wire from what I can determine is the wire for accessory outlet so should give you constant power.
You may want to check other strings to confirm this before blowing anything up.
Old Nov 25, 2010 | 01:57 PM
Fitfan46's Avatar
Well the diy Here says that the purple wire is an ignition powered wire, so it should work.
Old Nov 25, 2010 | 02:20 PM
Black3sr's Avatar
Looks like it.
I was in there last year for my floor lights. I think it was the pink and blue ones I used. Then this summer back in for the winkers on mirrors. I managed to get the mirror lights working opposite to signal lights. No idea which way I would be turning. Fun.
Good luck.
Old Nov 25, 2010 | 02:31 PM
Fitfan46's Avatar
Well according to the diy the pink wire is constant power(That could run the battery down!), I just need switched for the mirror. I helped my friend install angel eyes on his bmw about a year ago. No issues except running to walmart at midnight to get connectors to wire it to the lights.
Old Nov 25, 2010 | 10:28 PM
Fitfan46's Avatar
I finished the install about 7 pm. Had i not had one with a temp. sensor it would have taken about an hour and a half. With the temp sensor it took around 4 hours total, because i had to figure out how to route it.
Old Nov 26, 2010 | 02:18 AM
Black3sr's Avatar
Well done. So you had fun eh?
I still think a dark tint is the way to go
Old Dec 3, 2010 | 02:25 PM
annunC8's Avatar
Originally Posted by Black3sr
Well done...
... I still think a dark tint is the way to go
Negative, Beavis!
I want to do the mirror strictly for the compass and outside temp. I'd actually be pretty satisfied with the Fit's stock mirror if it had the temp. and compass readouts. Not really a fan of auto-dimming mirrors.
I have auto-dimming on my SUV mirror (plus temp. and compass)... one of the first things I do when starting the vehicle is disable auto-dim! Way too strong for me... can't see much of anything behind me after it dims.
Honda's stock mirror, when flipped up/down (whatever the preference), provides the perfect amount of anti-glare. Yet, unlike other stock auto mirrors, you can still clearly see what or who is behind you. The best stock rear-view I've ever encountered.
Like I said, I want to change strictly for the compass and temp. readout.
Old Dec 3, 2010 | 03:44 PM
Black3sr's Avatar
I don't need a compass.... the wife tells me where to go.
Temp. Hmm summer shorts, fall jacket , winter snowshoes and coat and mittens.
Old Aug 28, 2011 | 10:38 PM
BKKJack's Avatar
I know I'm late to the party, but I just picked up my Fit two weeks ago. I installed the GenK50A today. It was fairly straightforward, until I decided to confirm the above DIY with a multimeter. It turns out the pink and purple wires are the correct ones for constant and switched power, respectively. I was a little perplexed, because the power doesn't hit the purple wire until you turn the key to the "on" position, and it stays there after you turn the key off until you do some combination of removing the key and opening the driver's door. I can't tell you the exact sequence, because I didn't take the time to figure it out.
If you position the temp sensor on the right side of the upper grill, you can route the wires through the big grommet on the passenger side, come in behind the HVAC, and then back under the dash to the driver's side. This will you mean you don't have to spend the time separating the sensor wires from the power, and only have to run the wires down one A-pillar.
Old Dec 3, 2011 | 12:40 AM
jeon's Avatar
Thanks
Fitfan
Did the same thing on mine. I went ahead and purchased the same dimming honda mirrors (CIPA #36401)from partstrain.com and I could not deny the fact that the the price was great. I may try and install myself or if too difficult, my nephew is a honda mechanic so there’s no problem with the installation.
Old Feb 29, 2012 | 12:46 PM
smaglik's Avatar
resurrection....what mirror did you install, OP? Where did you route the wiring for the temp sensor?
GraphiK
Nov 1, 2012 02:40 PM
FinesseinTransit
Jun 26, 2011 08:25 PM
xonexlifex
Apr 25, 2010 06:09 PM
kenken
Jun 29, 2009 05:21 AM
beans2_98
Apr 5, 2007 10:47 PM
