Replaced Head Unit - audio sounds muffled
Old Jul 31, 2012 | 11:32 AM
angryhippie's Avatar
Last night I replaced the stock head unit with the Pioneer AVH-p3400bh. I'm loving the added features, but noticed that the audio sounds "muffled", or rather it doesn't sound crisp or clear. Many people have stated that simply replacing the HU made all the difference and audio was much better.
Does anyone have any suggestions or advice of what I can try to make it sound better without replacing the stock speakers?
Old Aug 1, 2012 | 01:50 PM
lashlee's Avatar
Did you use a harness, or did you hardwire it into the car?
I would pull the unit to verify you don't have one (or possibly more) of the speakers wired out of phase. Or while you are there you could also make sure that all four of the speakers are still working. The only other thing could be that you've got one of the wires or RCA's shorted to the speaker wiring.
Old Aug 7, 2012 | 11:06 AM
bustamelon's Avatar
Also, without knowing anything about this particular unit, some of the newer ones have built-in SPL tests that you have to run in order to calibrate the system. Just throwing that out there as another thing to rule out.
Old Aug 7, 2012 | 12:30 PM
krunk13's Avatar
adjust the eq
Old Oct 4, 2012 | 07:12 PM
x_25's Avatar
The stock head unit is EQed with lots of bass and treble. If you have a bass model with no tweeters and change the head unit, you will be left with mostly mid-range.
8strung
Aug 13, 2015 11:30 AM
FitPilot
Aug 11, 2009 11:11 PM
gettin~Fit
Aug 3, 2009 02:10 PM
Eugene.Atget
Apr 19, 2009 03:30 PM
Gbaby2089
Dec 12, 2008 11:01 PM
