Console lights not working?
How do I access two separate lights bulbs? One is for the transmission selector, the other is for the light which shines down over the cup holder area, forward of the selector lever, can anyone help please as my owner’s manual doesn’t cover these bulbs?
Your help would be much appreciated 😊 |
Blub over the cup holder , just pry down plastic panel , bulb is behind ;I think its a 194. The one for the shifter is a little harder, you have to take the center column out . It takes about 6 screws to remove the console ; the blub is in the bottom drivers side under the gear indicator, just follow the wiring harness . That bulb was a dealer only item.
Originally Posted by JerrySFL
(Post 1430304)
cheers |
